Oil rings
Oil rings
Post by Smellslike1974 » Tue Aug 10, 2010 7:51 pm
So I'm bringing each piston in the house to clean and re ring one by one in the nice air conditioning...I have a question though.How come the (I would believe they are stock*) oil rings have the two teeth that go in the hole but the aftermarket oil rings don't have these?Were the whole teeth In the hole a bad design or something?This would cause the rings not to spin...
First time i have done this.just making sure. :)
Re: Oil rings
Post by Smellslike1974 » Thu Aug 12, 2010 7:09 pm
Another ring questions is.the second compression ring from top has a bevel in it.The paper says that the bevel should face towards top of piston.But wat doesnt make since is where the rings are stamped is on opposite side of bevel,and the paper also says stamps go towards top of piston.
:help: the ring side view looks something like this /__] or if you flip it around \__].Im not sure what would be bevel facing up or down.
1bluegtx
Re: Oil rings
Post by 1bluegtx » Sun Aug 15, 2010 11:32 pm
Bevel goes up.
Its not numbers matching
It doesn't run on pump gas
11.73 at 115mph
Re: Oil rings
Post by Smellslike1974 » Mon Aug 16, 2010 8:21 am
1bluegtx wrote:Bevel goes up.
So the ring would be flat on top like this right. \__]
1bluegtx
Re: Oil rings
Post by 1bluegtx » Tue Aug 17, 2010 2:57 pm
Nope,install the ring so the bevel is on top facing the top of the piston.
11.73 at 115mph
Re: Oil rings
Post by Smellslike1974 » Tue Aug 17, 2010 11:19 pm
K i flipped all of them.Im getting good at It now. :lol:
