I see from the wiring diagram that it has all four headlights as hi/lo beam on the 72 SSP... Is there any legal or safety reason that I could not change it to the outside being hi/lo beam and the inner two as low beam only? The diagrams i see for the conversion relay kit always show the inner two being the high beams and the outside low. Or does it matter?? I am of the opinion that with 4 lights on high beam with two being amber it will look off. The reason is to do a rally style with the inner two amber and the outer two clear.
I am having a hard time remembering if the stock light switch has a half set and full open position? I could do something like half click is low beam inner lights, full extension is outside low and the switch for low to high, with the inner two off. I guess I'am trying to add fog lights but not add any actual phyiscal lights to the car.
Like this: Not a B-body but you get the idea
