'71 Rear Bumper, Steering Column, and Windshield Removal
Posted: Sun Jun 07, 2015 10:56 pm
Hello,
The name is Omar and I am a total newbie when it comes to restorations. I recently started work on my '71 bird. I am currently in the process of removing the rear bumper. I removed the gas tank, the license plate holder, and the taillight lenses. I can get to the two bolts closer to the center easily, but how do I get the ones on the outside? Should I remove lower valance or do it from inside the wheel well?
Also, I am in the process of removing my dash, and the steering column has to come out for that. Do I need to disconnect the gear linkage or does it slip through it?
Finally, I got the lower trim piece of the windshield, but I can't seem to figure out how to remove the trim that goes around the top. Do I need a special piece of equipment for that?
Thanks,
Thanks,
