Fender tag screws
Posted: Mon Dec 23, 2013 6:20 pm
Was the fender tag screws painted body color or not?
Thanks!
Thanks!
The resource on the web for the 4th generation Plymouth B-bodies
http://roadrunnernest.com/forum/
71bird wrote:From what I have been told, the fender tag was installed with one screw, then the tag bent upward so that paint would get under it. After paint the others screw which was unpainted was installed to fasten it down.
kenny wrote:71bird wrote:From what I have been told, the fender tag was installed with one screw, then the tag bent upward so that paint would get under it. After paint the others screw which was unpainted was installed to fasten it down.
same thing i read - furthermore if i remember what i read correctly normally the front screw was the painted one the rear was unpainted and if you had a 2 tag car the center screw that hits both tags was painted while both outside screws were unpainted
Never heard of any of this before. Guess either I have one painted and the other not, or paint them both. If I leave one unpainted, does anyone know what the unpainted ones finish is? It's not a concours correct car I'm building.JimT1971RR wrote:kenny wrote:71bird wrote:From what I have been told, the fender tag was installed with one screw, then the tag bent upward so that paint would get under it. After paint the others screw which was unpainted was installed to fasten it down.
I read the same. In addition, I used to own a 67 Barracuda which still had the original paint under the hood and the front screw was painted while the rear one was not. There was also a visible bend mark on the front/top corner where it was bent upward for painting.
I agree just unfinished natural no phosphate or zinc type coatingsJimT1971RR wrote:To my knowledge, it was just installed unfinished. My old Barracuda's screw was simply covered with surface rust after 40 years. I would put a clear coat on the screw to prevent the rust but that is all.
