Dash Pad Covers??
72 cuda repli-mod
Dash Pad Covers??
Post by 71_bronze_gtx » Tue Oct 29, 2013 7:02 am
Has anyone opted to try a dash pad cover rather than replace or refurbish? If so, did it fit right? Does it look good?
My pad has one vertical split right over the left edge of the glove box door and is otherwise in good shape. I'm not at the point where I want to take it out.
kenny
My Cars: RM23N1G107875
Re: Dash Pad Covers??
Post by kenny » Tue Oct 29, 2013 7:18 pm
I have a friend who used one on a 71 charger, same dash, and honestly it looked pretty good. He cut away the area around the cracks then sprayed some of that expanding spray foam insulation from the hardware store, after it set up he shaved it back down to level with the surrounding area and made several test fits and had to cut some off the original pad around ends to make it lay down good but when he glued it down it looked good i guess like a lot of things extra time and effort during preparation yielded a nice result
72 cuda repli-mod
Post by 71_bronze_gtx » Tue Oct 29, 2013 11:06 pm
Thanks - that's good info. I ordered one today direct from Coverlay. $62.43 + $14.74 S+H. I almost bought on ebay for $62 + ~$50 shipping. Watched a video about install right on the listing and decided to check Coverlay direct. 43 cents more on the pad, $35 less on shipping. Tough decision. Will post results pics.
gary
Post by gary » Wed Oct 30, 2013 3:00 am
I bought one from Hardens about 5 years ago painted it, installed it and have been happy with the results.My original dash pad was so bad I had to buy a used one for the cover to be right.But still 4 to 5 Hundred cheaper than just dashes :beer:
Post by sdweatherman » Tue Feb 21, 2017 10:19 am
Rick, I think you are going to have to describe your question a little better - I am not sure what you are asking.
Thanks,
Post by rr6pak » Sun Mar 05, 2017 7:51 pm
If looking for a good, quality dash pad, get a hold of abcmoparts.com and be done. Customer service is top notch, etc.
Post by rr6pak » Thu Mar 09, 2017 8:52 am
IMOP, I wouldn't get a cover. In the heat, they'll warp or the craftsmanship isn't very good. Save some money, if that's the issue, and get a recovered one or have your original done. You'll be glad you did.
Bruzilla
My Cars: 1974 Plymouth Roadrunner, 440/Auto, Black/Black
Post by Bruzilla » Thu Jul 13, 2017 10:11 am
I used a cover. It's been on for five years now, and it did warp a bit in the center, but thanks to an unscrupulous shop owner the car sat in the Florida sun and heat for over three years without being opened up. The little warp was there when I retrieved the car about 18 months ago, and it hasn't gotten any worse now that the car is closed up all the time.
71runnerm51
Post by 71runnerm51 » Mon Aug 07, 2017 4:58 pm
I've had mine on for about 12 years still looks good
