Rocker question...
Posted: Sat Mar 26, 2005 9:21 pm
by ccb_v2
Ok, so I get the carb tuned in better on the '72 318 and try it out on a beautiful day... runs well, no problems (was backfiring because it was too rich). Well I take it out a few days ago on another great day and there's a tap-tap-tap from the engine.... pop the hood and it sounds like its a rockewr hitting the valve cover... like you take two wrenches and tap them together... So I pull the cover but cannot see any way to adjust the rockers from the top. Anyone have any advice?
Posted: Mon Mar 28, 2005 1:11 am
by 71383bee
Assuming that you have a stock 318, there is no way you can really adjust those shaft rockers. If a rocker is tapping the valve cover then it is just plain broke.
Did you see any damage while the cover was off? Metal shavings, etc? A broken pushrod is more likely the culprit and those are typically caused from a stuck/bent valve or wiped cam lobe. Turn the mortor over slowly by hand or bump the started and make sure all of your valves are opening.
Have you done a compression test on the motor at all recently?
Posted: Mon Mar 28, 2005 10:04 am
by ccb_v2
No damage or any other abnormal signs when I pulled the valve cover off. Engine has about 44000 miles on her. From what I can recall my 305 in my 88 camaro had adjustable rockers, and I was suprised when I saw that these were not adjustable (granted this is a '72 and the 305 is an '88). Comression test is next in line actually. Thanks for the info, I appriciate it!
