Flywheel problem
71dustrunner
Flywheel problem
Post by 71dustrunner » Sun Mar 06, 2005 6:14 am
I have a -71 roadrunner , 440engine - 4 speed , I have bought a new set of Centerforce flywheel 143 tooth and I have a powermaster ministarter , these two does not fit together !! Could the flywheel be too big ?
It seems that the axel in the starter gets too close to the flywheel and is not possible to line up . Any solutions ? please advice ,
thank's
Post by Dave » Tue Mar 08, 2005 11:51 am
Could you possibly have a true 11" flywheel and a bellhousing for the 10.95" unit? I belive there were 2 different housings for the 2 different flywheel applications. Double check that. the true 11" flywheel is the older variant, and many suppliers I've seen refer to the 10.95" one as 11", but it's not the true 11" unit.
I'm not sure if there's a difference between the tooth count on the 10.95" and the 11".
71dustrunner
Post by 71dustrunner » Tue Mar 08, 2005 2:30 pm
Dave wrote:Could you possibly have a true 11" flywheel and a bellhousing for the 10.95" unit? I belive there were 2 different housings for the 2 different flywheel applications. Double check that. the true 11" flywheel is the older variant, and many suppliers I've seen refer to the 10.95" one as 11", but it's not the true 11" unit.
Hi Dave thanks for the answer do you know where i can buy a 11 " housing. Regards Anders
fly wheel
Post by 71440 gtx » Tue Mar 08, 2005 7:41 pm
hi the fly wheel in 68 to 69 383 440 hemi are 11 with 11clutch the70-74 383 400 440 hemi flywheels are 10.50 with a 10.95scalloped clutch. :beer:
Post by Dave » Wed Mar 09, 2005 10:04 am
Thanks 71GTX, that's exactly the info I was wanting to give him. I knew there were some differences, but couldn't remember the applications. :)
