Wheel Size....
72RR400
Wheel Size....
Hey I know there is already a topic sort of like this but mine is a bit different. Ok the question is, what is the biggest tire size that can fit on the back of a '72 road runner if it is mounted on a Rallye size 15-8 with NO backspace?
Could a 275/60-15 work, or maybe a 295/60-15?
- Dave
I'm not sure where you are going with "NO backspace". That would have the wheel itself partially outside the quarter panel. I'm not sure you could get a set of rallye wheels made up with no backspace at all and have them look ok from the front.
Unless you mean a 15x8 rallye with just the factory backspace, which I think is 4.5". (Ok all you rallye wheel guys, correct me if I'm wrong there.
) Anyway, if you mean just using a stock rim, you could easily to 275's, 295's would be pretty close clearance to the quarter panel. On the rims I have for Project Blue Bird, they have 4.75" backspace, and I have the 295's exactly centered in the wheel house, with 3/4" clearance from both the spring on the inside and the quarter panel on the outside. Figure the factory rallye would move that whole thing 1/4" outward, so you'd be looking at 1/2" or less from the quarter.
If you looked at 275's you'd have a good bit more clearance due to the smaller tire in general, but also, you'll drop a good bit in section width on the tire since you wouldn't have the same sidewall bulge that you do fitting a 295 on an 8" rim.
Hope that helps!
Hope that helps!
72RR400
- Dave
72, don't feel bad, we all have those days.
Only way to learn is to ask questions. As I've always said, there's no such thing as a dumb question - just dumb people... er... no wait... that's dumb ANSWERS.. yea, thats it.
Anyway, glad I was able to help you. If you want, I can see if I can dig up the spreadsheet I used in working out tire widths, wheel size and backspace. I'm not sure if I saved it, but knowing me, it's around here somewhere.
71GTX, well, here's what I have:
A couple from when I did a test fit on my SSP:
This is the only one I have of them on the Road Runner. It doesn't have the best detail, but it's better than nothing.
To convert Metric to inches just multiply by .03937
for tread width....
EX. 275/60/15 275mm = 275 X.03937 = 10.82 inches tread
Tire diameter
10.82" X .6 ,(60%)= 6.5" sidewall height
6.5 X 2, ( to sidewalls) = 13" + 15" diameter wheel = 28" tire diameter
That will get you your tire dimension- the backspacing you'll have to figure with a straight edge from the wheel mounting face and a ruler to the wheel housing lip and spring. You should be able to determing the back spacing from there.
for tread width....
Tire diameter
