gcoupe72
Post
by gcoupe72 » Mon Feb 06, 2012 3:25 pm
Our '72 Runner has two extremely rusty back up lamp sockets.I think at one time the lamps were 1/2 full of water! One side won't hold a bulb.
Has anyone replaced these sockets?
I'm guessing I could cut up what's left, and maybe glue in something from a parts store.
I'd be happy to hear from someone who's done this, and could offer any tips.
Also, is there a trusted source for new tail lamp gaskets?
Post
by 71bird » Mon Feb 06, 2012 3:50 pm
I had the same problem.I actuality took mine apart as far as i could get them and sraped and lubed ect.over and over as good as i could get them.Their working, but not like new, i noticed one backup light was interment and i had to take it apart and wiggle it around to get it to ground right,but who knows how long that will last.I think the next step would be is to buy new ones at a parts store just for the inner workings (springs and pigtail ) and splice wires and put them back in the orig. socket.Also all the 1157 light bulbs on the market today are of the Kung Fu variety.
PLUM BAD
- My Cars: 72 Roadrunner clone (drag car)
72 Roadrunner restoration project
Post
by PLUM BAD » Mon Feb 06, 2012 9:56 pm
PLUM BAD RACING
71ChallengerSE
1971 Dodge Demon 'Sizzler'
Post
by 71ChallengerSE » Mon Feb 06, 2012 10:19 pm
Interesting, any pics of them lit up?
Post
by sdweatherman » Tue Feb 07, 2012 12:12 am
Thats a good looking fix. I will probably have to do something similar, as my sockets are a little crusty also. Landon1 had this same question in a previous post. rr6pak forwarded him to a link on moparts that also shows someone modifying their tail light housings. Here it is:
http://board.moparts.org/ubbthreads/sho ... PHPSESSID=
gcoupe72
Post
by gcoupe72 » Tue Feb 07, 2012 11:36 am
Wow Plum, thanks for the photos!
sd, thanks for the link.
Some great ideas, I hadn't even considered using "modern" plastic sockets.
That should keep this from happening again.
And Plum Bad, I noticed your new sockets used different bulbs.
Like 71, I'm curious how the brightness works with your original brake,turn, and running light bulbs?
PLUM BAD
Post
by PLUM BAD » Tue Feb 07, 2012 10:44 pm
The upper taillight sockets are original. I just cleaned them up in the blast cabinet, put a little epoxy around them to seal them, and painted them black. I used the same 1157 bulbs that came originally. I guess you could use 2057's if you wanted brighter taillights. For the lower back-up light sockets I used 3156 bulbs, which are probably the same brightness as 1156 that the factory used.
PLUM BAD RACING
