What type of material are most of the splash shields made?
Several of the splash shields/guards on our cars are made of a flat rubbery substance about 1/8 of an inch thick. Since I have most of my original pieces, I figure if I found the right material, I could just cut my own new ones. Does anyone know if this material is available for sale at a hardware/auto store - or through someone else? The splash shields i am mainly talking about are the fender/headlight shields and the rear inner fender shields. Thanks in advance!
Re: What type of material are most of the splash shields mad
For the cost, why not just buy a pre-cut set. They're not that expensive.
http://www.detroitmuscletechnologies.com/
Jim's stuff is excellent.
As is all his reproductions, top notch!
Past thread about the splash shields.
Yep, spotted his stuff already. Just exploring all options for saving a dollar here and there. Figured if I could find a suitable material, I could just make them myself. Thanks for the feedback! Scott.
- Diriccatiticka
- My Cars: 1972 Plymouth Roadrunner
I made mine on my daily driver a couple years ago, and probably will make some for my Road Runner here soon.
I used EPDM rubber sheeting for mine. Held up great so far. If you can still piece your old ones together, they make a good stencil.
Good luck!
Good luck!
'72 Road Runner
Currently Engineering New Setup!
Ronnman
The material is Masticated Rubber Sheet.
Ron
Ron
Thanks for the leads on the materials! I will check them out.
