body mounts need help
beep beep guy
My Cars: 1974 roadrunner clone
Post by beep beep guy » Tue Apr 12, 2011 6:32 pm
Ok here is a few pics of the front body mounts how do you get them out? I was told they slide out but the one in pic has a sleeve were bolt goes in hmmmm
Uploaded with ImageShack.us
Mopar or no car! Beep beep
beep beep guy
Re: body mounts need help
Post by beep beep guy » Wed Apr 13, 2011 10:54 pm
Anyone know were I can buy the rubber body mounts from?
1bluegtx
Post by 1bluegtx » Thu Apr 14, 2011 9:27 pm
The sleeve should just pull out (probably rusted to the rubber).You probably have to lower the k member a little to get them out or get the new ones in.
Summit has the bushings in polyurethane:
http://www.summitracing.com/parts/PTP-4 ... /?rtype=10
