Hood Springs
Posted: Sun Oct 31, 2010 4:04 pm
I'm convinced my Roadrunner is trying to kill me. It has made several attempts to decapitate me.
Apparently, it does not have the correct hood springs on it. They barely have enough strength to hold the hood open. The slightest disturbance will send the hood crashing down. I've been using an old broom handle as a safety measure. While it's an effective temporary solution, it's a bit tacky.
I've since learned that Roadrunners use a heavier spring than the Satellites. This is regardless of Air Grabber or not, and all Roadrunners use the same spring.
Unfortunately, there is a shortage of 71/72 Roadrunner parts cars around here from which to harvest a set of springs.
I have come across several 71-74 Chargers though, and they seem to have a heavier spring. I nabbed a pair in a recent trip to the salvage yard.
Does anyone know for sure if these are the same as Roadrunner springs? They're definitely heavier than the one currently on my car. They aren't too strong, are they? I don't want to have the opposite problem and the rear of the hood bulge up. I'd like to know for sure before I go to the trouble of blasting, painting and installing these.
Also, any tricks to installing them without causing grievous harm to surrounding painted surfaces?
Bought a set of Charger hinges off eBay that came with these springs, .245" wire, 18 and a half coils(note the way the last hook faces).
