Glove Box Door Lock Removal?
EaglesCall
Post by EaglesCall » Tue Jun 02, 2009 12:03 am
Another one that should be simple, but apparently isn't for me. How do you remove the lock from the glove box door? I'm trying to get a dash frame and peripherals ready to send out for blasting - this is the last piece. Thanks.
'72 Satellite Sebring Plus
'99 Dodge Dakota SLT 4X4
'57 Nash Metropolitan (Hey - it's an adopted orphan!)
Re: Glove Box Door Lock Removal?
Post by 72RoadRunnerGTX » Wed Jun 03, 2009 1:25 am
As I recall, insert the key into the cylinder to retract the tumblers then locate the access hole in the latch, insert something to release the cylinder from the latch.
EaglesCall
Post by EaglesCall » Thu Jun 04, 2009 12:48 am
I was afraid it was similar to an ignition switch removal. I'm going to have to start digging through boxes and see if I kept the trunk lock - I'm thinking this is also where a key might be .................. I hope !!!! Thanks for the information.
EaglesCall
Post by EaglesCall » Sun Jun 07, 2009 12:24 am
You were correct, you muust have the key. I did find one for it. You have to slide each of the keyed tumblers in line with the cylinder as you pull to get it apart (one at a time). Thanks for the help.
