Whats the best way to install reveal clips?
BarryBum
Post by BarryBum » Wed Feb 25, 2009 9:34 pm
I got my reveal clips for the rear of my 71 Satellite today. Theres got to be an easier way to install these things, I am afraid I am going to break them. Whats the best way to clip these things on the little stud?
fourforty6pac
Re: Whats the best way to install reveal clips?
Post by fourforty6pac » Thu Feb 26, 2009 6:12 pm
Are you talking about the windshield and back lite? If you are all you do is slide them on the stud. There is a slot on the bottom of the clip. If the stud is missing you can get clips with a small sheet metal screw attached.
fourforty6pac
Post by fourforty6pac » Fri Feb 27, 2009 6:00 pm
I forgot to mention that you probably will have to beat them. It is best to do it with soft like wood or plastic. you won't break them. Be careful not to chip your paint.
moonman
Post by moonman » Fri Mar 06, 2009 3:42 pm
fourforty6pac wrote:. If the stud is missing you can get clips with a small sheet metal screw attached.
I wish I knew this before I turned up some replacements for the rotten ones around my windshield and welded them into the patch panels I'd made . incidentally who makes them ?
cheers Doug
Satellite owner from over the pond
fourforty6pac
Post by fourforty6pac » Sun Mar 08, 2009 4:18 pm
