What does it take to swap out for a Tuff wheel?
billzilla
Post by billzilla » Tue Jan 20, 2009 2:39 am
I have a regular stock wheel in my SS and want a Tuff for the usual reasons. What does it take to swap out the old one for an original (or repro) Tuff wheel?
Re: What does it take to swap out for a Tuff wheel?
Post by 471Magnum » Tue Jan 20, 2009 8:44 pm
Just need the wheel, horn switch, horn button, and adaptor collar.
Post by landon1 » Wed Jan 21, 2009 9:40 am
i think you can pick up a repro and it may come with the install kit, but then you have to purchase the horn button separate - if not, it's made by grant, so i'd guess that a regular install kit would work
72GTX4SPEED
Post by 72GTX4SPEED » Sat Jan 24, 2009 11:41 pm
check with dales cuda shop. i think their kit is complete or just may need the collar. the collar is easy to find.
clem
(40.32 KiB) Downloaded 1122 times
patrick
Post by patrick » Sun Jul 18, 2010 10:59 am
I just bought a repro tuff wheel for a steal on E-bay because it was allegedly blemished. It's the foam vinyl type, but mimics the original look.
Anyway, this is going on a '73 Road Runner. I can't seem to locate the collar/adaptor anywhere. Is it the same as the E-body one (accordion style)? Is there an aftermarket universal adaptor? This does not have the Grant-style bolt pattern, it's not a Grant.
Also, the horn button seems to snap on and be pretty solid. How the heck does it honk the horn? I presume you press the center button, but it doesn't really flex. Is there a spring that bounces it back up or something? I don't get it at all. Or does it just down like a millimeter around the edge to blow the horn?
100% Death Proof
patrick
Post by patrick » Wed Jul 21, 2010 10:22 am
Okay, just bought the "smooth" style Tuff-wheel adapter off E-bay since I believe the "accordion" style is for E-bodies only. Hope I guessed right.
100% Death Proof
72Satellite440
Post by 72Satellite440 » Wed Jul 21, 2010 8:26 pm
my 72 came with a crappy looking tuff wheel with adapter...Not sure mine will work on ur e body but I think i still kept the adapter around...So if the one you ordered doesnt work send me a pm...I switched to the 3 tier padded...much happier with it.
72Satsebring
72-SaTeLliTe440-Dan
Post by Eric » Thu Jul 22, 2010 12:16 pm
Smooth is correct for a 71, not sure about 73
