Radiator overflow 1972 Roadrunner
N96RR1972
Post by N96RR1972 » Sun Sep 21, 2008 5:44 pm
I happen to have a radiator overflow bottle on my 1972 Roadrunner, It looks original....Did they come from the factory with them?.............THANKS
Re: Radiator overflow 1972 Roadrunner
Post by 71440 gtx » Sun Sep 21, 2008 6:06 pm
yes in 72-74 b-body
not in 71 :D
Post by 1972RM23 » Sun Sep 21, 2008 6:08 pm
Max. cool package.
Post by rr6pak » Mon Sep 22, 2008 2:37 am
71440 gtx wrote:yes in 72-74 b-body
not in 71 :D
Wish they did for the '71 though. :(
71Runner
Post by 71Runner » Mon Sep 22, 2008 9:06 am
I was thinking of adding a '72 unit to my 71. Anyone have any photos of a '72?
Post by rr6pak » Mon Sep 22, 2008 11:25 am
71Runner wrote:I was thinking of adding a '72 unit to my 71. Anyone have any photos of a '72?
I'm going to do the same just for the added insurance. Strange they didn't come with one :wink:
Post by 71440 gtx » Fri Oct 03, 2008 1:29 pm
a 72 one for b-body :beer:
71Runner
Post by 71Runner » Mon Oct 06, 2008 9:22 am
Thanks for the photo 71440 gtx. Damn, that's a lot of extra crap that goes along with it! I was thinking it would mount more like the windshield washer bottle.
Post by rr6pak » Mon Oct 06, 2008 9:54 am
71Runner wrote:Thanks for the photo 71440 gtx. Damn, that's a lot of extra crap that goes along with it! I was thinking it would mount more like the windshield washer bottle.
Should be able to fab something simple without all of the extra stuff, IMOP. Correct me if I'm wrong, but doesn't it go on the pass side of the radiator? Anyone have a detail pix with it installed :)
Post by 71440 gtx » Mon Oct 06, 2008 12:41 pm
nope is go on driver side in 72 on 73- 74 pass side on b-body
:beer:
Post by 72RoadRunnerGTX » Mon Oct 06, 2008 1:27 pm
From my research, I believe the picture above is correct for 72 b-bodies. Pictures I’ve seen have the brackets bolted the top of core support on the driver’s side. Pretty hard to come by from what I can tell. I picked up one of these set-ups, Ebay listing1,Ebay listing2 a few years ago based on it’s description but have come to believe that it is only correct for 73-74 E-bodies. I believe it will fit my 72 b-body and may end up using it.
ROGERLEE
Post by ROGERLEE » Mon Oct 06, 2008 10:20 pm
if you don't care for the correct stuff, there are a lot of old mopars out there, that comes close, for example i was in the junk yard the other day, came across a 73 chrysler imperial with a 400, had a tall thin bottle almost like that, and has all the brackets, i think i am going to grab it for my 71. D id you see the prices the fella from georgia had ?, 90 bucks for a bracket and 90 for the bottle, by the time the shipping is added up you are looking at over 200.00 bucks for a radiator overflow. I had a 2 litre coke plastic bottle on my 73 cuda, never ran hot, just ran a hose to the bottle and screwed on the cap, the way it was configured you really had to look hard to see it....just my 2 cents.
72Rdrnner
Post by 72Rdrnner » Tue Oct 28, 2008 8:06 am
1972RM23 wrote:Max. cool package.
Just for my own edification what was the "Max.cool package"? My 440 A/T with factory air did not have an overflow bottle. It does have the correct radiator and fan along with the vacuum valve in the cooling system that speeds up the engine by advancing the timing when it reaches a certain temp, as well as the vapor cannister between the fuel pump and the carb.
But no overflow bottle, just the hose from the filler neck that goes down the driver side.
I checked the build sheet and can't find a block that says anything about a cooling package.
My car was built in Jun 1972 so was a relatively late production run car.
As I said, just curious about the subject.
moparmodeler
Post by moparmodeler » Tue Oct 28, 2008 10:00 am
My 72 Satellite is Base RL model with the only option being the light package. It is so basic that it has vinyl flooring rather then carpet.
To the point, I have a over flow bottle different then the one posted here earlier. I most say though that my car also has a slant six and may not need such a large container as a v-8 model might.
