Water Pump
beepx2
Water Pump
Post by beepx2 » Wed Mar 19, 2008 11:37 am
Now that the weather is getting warm, my 383 will start to run real hot. I've already added a new radiator and installed an electric fan. I plan to get the Milodin thermostat from Summit. What I need now, is some suggestions for a high capacity water pump. Any and all suggestions would be appreciated. :help:
Post by 71440 gtx » Thu Mar 20, 2008 8:24 pm
get a ac water pump. for the car i :beer:
Post by landon1 » Thu Mar 20, 2008 11:47 pm
are you sure your gauge isn't messed up? replace the sender and then see??? mine wasn't working right, so i put an add-on gauge in and it was fine...then that gauge said i was beyond overheating, like 285, so i replaced the sender and hooked the factory gauge back up and now it works alright - i'm right in the middle...otherwise, they sell little propellers (i think flow-kooler or milodon) that mount on the shaft, which is another option, they sell pumps that are supposed to flow 33% more and then you add the prop if you want more flow
Post by Smellslike1974 » Thu Mar 20, 2008 11:55 pm
71440 gtx wrote:get a ac water pump. for the car i :beer:
theres a difference?
I have like 3 water pumps,and i wanted ac,but the bigblock wasenet hooked up for ac,how do i know wich one is ac or not.
Ill take pics tomorrow if u want.
Post by 71440 gtx » Fri Mar 21, 2008 2:28 am
yes post pics of the water pumps :beer:
Post by Smellslike1974 » Fri Mar 21, 2008 2:25 pm
Hmm
Last edited by Smellslike1974 on Fri Mar 21, 2008 3:34 pm, edited 1 time in total.
Post by 71440 gtx » Fri Mar 21, 2008 3:29 pm
that is not the Water pumps is a Water pump housing, the water pump goes in those :lol:
Post by Smellslike1974 » Fri Mar 21, 2008 3:33 pm
well then wheres my in-there water pump thingys :mad:
Im not sure what your talking about,thats all that was on my engine.Is it the thing that sticks out for the pulleys?lol
Post by 71440 gtx » Fri Mar 21, 2008 3:42 pm
Smellslike1974 wrote:well then wheres my in-there water pump thingys :mad:
yes water pump thingys that sticks out for the pulleys :lol: meep meep
Post by Smellslike1974 » Fri Mar 21, 2008 5:59 pm
I father is not a good teacher!
thats what he called it. :lol:
Post by mopar71 » Fri Mar 21, 2008 6:56 pm
The pump impeller is different on an a/c car vs non a/c.Of course I am talking about the 383.But the a/c impeller used less hp to drive. I always replaced my pump with an ac waterpump even thou I dont have a/c. They are interchangeable. 8)
aerodynamic
Post by aerodynamic » Fri Mar 21, 2008 8:49 pm
I assume you have a 4 core radiator? I've had a couple of these big block cars, and I find a 4-core and a Hayden Flex fan work wonders, and I'm in Florida! Never needed anything fancy for a water pump.
73 Road Runner 400 auto
