what does it take for a RR horn to work on a Satellite car?
linemup
Post by linemup » Mon Mar 03, 2008 2:52 pm
I remember reading that I would have to change the horn relay or something. I want a RR horn on my RR CLONE. Is the wiring different since the Satellite has a low and high note? I can't recall but seems like there is a difference............in other words, you can't just stick on a RR horn and it work correctly. I may be wrong and hope so actually. Thanks guys..painting car next weekend.
Post by 72RoadRunnerGTX » Mon Mar 03, 2008 6:29 pm
You have to have the correct horn button on the steering wheel (the one that says “Beep Beep”) before the RR horn will work. Just kidding! Just replace one of the regular horns with the RR horn and remove the other horn. The unused wire is usually found wrapped up in the forward lighting harness or deleted altogether. No other changes necessary.
linemup
Post by linemup » Mon Mar 03, 2008 9:20 pm
I don't know why I thought that I had been told about using a different relay or something..............thanks bud.
