72 Sat - Cooling upgrade
71383bee
Post by 71383bee » Fri Jan 25, 2008 5:43 pm
Hello all,
It's been a long while since I posted on here. I sold my 72 318 satellite to a good friend of mine about 2 years ago now.
It turns out the 318 I rebuilt is abit too hot for the old 18" radiator. The opening will easily fit a 22" radiator which is what my friend wants to do. My questions are the following:
1. Was a 22" radiator offered for a small block for this body?
2. If not is it possible to modify a BB 22" radiator so that the input is on the right side versus the left.
thanks.
Post by mopar71 » Fri Jan 25, 2008 6:01 pm
My 22" radiator has the top hose on the right side (when facing the car)and so is the bottom.Part number is 299895 but its for a 70 383 Manual trans.
Maybe this chart can help you,The only problem is you wont know what side the hoses are.
http://www.mopar1.us/radiator.txt
71383bee
Post by 71383bee » Sat Jan 26, 2008 2:45 pm
Thanks for the help
I'll try on moparts too.
From your list it looks like a 22" rad was not made for a sb in 72, but one was made for an e body and an a body.
AFIK there was not a difference in the water pump discharge on the 340 vs. the 318 so I think it might be worth trying to find a 22" 340 radiator for a similar year A body.
Post by 71440 gtx » Sat Jan 26, 2008 3:26 pm
3574628 1972 b E 22 340 318
it a 19 rad not 18 rad for 318 in 1972
Post by mopar71 » Sat Jan 26, 2008 10:19 pm
Once he gets the radiator,tell him to
get a good high flow thermostat like a Milodon High-Flow Thermostat.160*
8)
