flapper door color
bandman
flapper door color
Post by bandman » Sat Jan 19, 2008 12:47 pm
Hi guys,
I was wondering if anyone has an idea of what color the flapper door is? I know it is orange, but which one.
I scrached mine up a little, and I had to retack a weld, and now I need to touch it up before I go in for final assembly (woo-hoo).
Thanks for any help you can give.
Dennis
Post by Eric » Sat Jan 19, 2008 9:06 pm
Not sure if you're talking about the air grabber flapper door? I don't require there being any welds on it.
Anyway, if that's what you're referring to, I believe it's the same color as air cleaner lid orange.
bandman
Post by bandman » Mon Jan 21, 2008 10:24 pm
Thanks Eric.
I did mean the air grabber flapper door. Mine is a reproduction. At the end where the actuator is there is a small tack weld that holds the arm that hangs down from the main bar..........Just working with the materials that are available to me. Plus it is so cold here I have a hard time thinking straight.
Dennis
Post by Eric » Mon Jan 21, 2008 11:36 pm
only the door is painted orange, the rod and arms were plated, not painted
