Hood springs
Posted: Thu Mar 29, 2007 6:01 am
by Capsule
Hi guys,
I'm having trouble with my hood, it won't stay open when the motor is running. The springs will hold the hood open with the motor shut off but when motor is running, the vibrations makes the hood close.
I'm guessing my hood hinge springs are just old and needs replacing. I can only find AAR cuda fibreglass hood springs, anyone know where to find a set that will fit my '71 Air Grabber?
Capsule
Posted: Thu Mar 29, 2007 8:32 pm
by Eric
IIRC air grabber hoods used stronger springs than standard hoods, so if you're using satellite hood springs on an A/G hood.....
Posted: Thu Mar 29, 2007 10:50 pm
by 1bluegtx
71 plymouth airgrabber hoods used the same springs as 71-72(probably73-74 too) chargers with flat hoods.
Posted: Fri Mar 30, 2007 9:16 am
by bruce
I'm using the hood hinges and springs from my standard hood on my air grabber hood. They won't hold the air grabber hood open. I have to use a prop rod... The AG hood is WAY heavier, and the scoop mechanism adds some of that weight on the FRONT of the hood (think big fulcrum action on the springs over the length of the hood).
Posted: Fri Mar 30, 2007 3:37 pm
by fourforty6pac
The charger hood springs work great. They are a little stronger because the charger hoods are heavier. Good Luck!
Posted: Fri Mar 30, 2007 4:47 pm
by Capsule
Thanks guys,
I will be looking for some Charger springs then! If any of you guys by chance should have a set of springs on hand, please let me know.
Capsule.
Posted: Fri Mar 30, 2007 6:37 pm
by 71440 gtx
Capsule wrote:Thanks guys,
Capsule.
you are a lucky man today
i have two sets for 71-72 they are from a 71 4 door dodge coronet
Posted: Sun Apr 08, 2007 9:07 am
by Capsule
Hey 71440 gtx,
are these springs he same, stronger ones as on the Chargers? If they are, I would like to by a set from you!
I already have the standard Runner springs.
Capsule
