Front spring mounts rubber
Posted: Mon May 22, 2006 2:35 pm
by 71_DEPUTY
looking to see where the rubber is available for the 73 RR.
looked around but could source any!!
John Mac
Posted: Mon May 22, 2006 4:56 pm
by 1973 gtx/rr
To 71 Deputy,
If you are referring to the" rubber"for the K member bushings,then these are available in urethane from Performance Suspension Technologies.I did mine a couple of years ago as the originals
had dissintegrated and the results were well worth the investment. Hope this helps you.
Posted: Mon May 22, 2006 6:44 pm
by 71_DEPUTY
nope- looking for the rear springs- perch mount onto the frame.
but thanks- haven't got to the front yet- will keep those in mind!!!!!!
John Mac
Posted: Mon May 22, 2006 9:04 pm
by 1bluegtx
Does it still have the oval spring eyes?If so Energy suspension carries the bushings.You might want to consider changing to springs with round spring eyes as the oval ones are prone to breakage.
Posted: Tue May 23, 2006 8:58 am
by 71_DEPUTY
oval???? never seen those before- mine are round as a donut hole!!!! lol
ma mopar doesn't stock them anymore??????
got the rubber out of one this weekend- it has a outer steel cover- then rubber and then the innear steel section for the bolt to go through.
didn;t really look to bad- the outside was falling apart but the inside was still good.
guess for sitting for over 15 + years the rubber wasn't torn apart!!
Posted: Wed May 24, 2006 8:08 pm
by 1973 gtx/rr
Hey Dep,
Just looked thru my PST catalog and I think I found what you are looking for.They list a rear
spring polygraphite bushing kit for 73-79 B bodies for $100. US.They come in 1.5" or 2.0"
inside dia's.You can check them out at P-S-T.com
Posted: Wed May 24, 2006 9:07 pm
by 71_DEPUTY
thanks- will check out their site!!!!!!
Posted: Thu May 25, 2006 2:16 pm
by 71_DEPUTY
holy crapola!!!! buddy at NAPA found them for me!!!
part # NCP 274-6512 $ 11.01 and taxes in Candian dollars!!!!!!!!!!!! for two of them!!!!!!!!!!!
can't believe that- they look like they are $ 60-80 units!!!!!!!!!!!!
will try this weekend to put them in! will let you know if they are the right ones!!!!
this maybe a goody for the tech section???
