Retractable 3 point seat belts
Post by CtownRunner » Tue Aug 28, 2007 6:31 am
Does any know of a good after market 3 point retractable seat belt that will work in our cars. Just lookin for a clean and strong installation.
Ron_M
Post by Ron_M » Wed Sep 05, 2007 1:44 pm
I "attempted" to use the Andover belts in my 74 RoadRunner. The retractor that anchors behind the lower rear interior panel (inside the unibody) would not clear and I was unable reattach the lower panel. I did not want to butcher the panel and IIRC couldn't mount the retractor on the outside (cabin side) of the panel. Ended up selling the belts (at a loss) on Moparts. Total waste of time and Andover was of little (if any) help.
I inquired with SnakeOyl about rebuilding my 74 belts and they would not touch them claiming no parts available.
If I were attempt this again, I would probably try to use N body Dakota pieces and then, only if they were free!
What I ended up doing, was using 1973 model year shoulder straps with a 74 male end stitched on and secured it to the car like a shoulder strap. The original 74 issused belts were left in place.
My original belts tend to "jam" and will not always work without a struggle.
Post by 471Magnum » Wed Jan 02, 2008 9:32 pm
I run the XV belts on mine. I believe they are made by Andover.
Anyway, they fit okay. The receiver side is a VERY tight fit between the seat and the console.
Also, the roof anchor is quite far back, so its a pretty good reach to grab the belt.
72Rdrnner
Post by 72Rdrnner » Fri Jan 04, 2008 6:46 am
471 Magnum,
That is exactly what I'm looking for on my Roadrunner.
Couple of questions:
1. Do the retractors mount in the stock position behind and outside of each seat?
2. Does the top part mount use the stock anchor hole?
My inside anchor has also been a tight fit, and it seems to depend on fore/aft seat position. At my height it apparently is the "tight" location!
For now I just left the shoulder harness out.
Post by 471Magnum » Fri Jan 04, 2008 7:43 am
72Rdrnner wrote:Couple of questions:
Yes & Yes
