1974 Satellite fender tag
73'BIRD
My Cars: 1973 Roadrunner, 1974 Satellite
Post by 73'BIRD » Sun Apr 03, 2016 9:38 pm
:bump: tried to put this in the decoder and didn't work not sure I entered it correct. Could someone tell me about this car
20160403_121206 (1).jpg (24.76 KiB) Viewed 45311 times
moparite
Re: 1974 Satellite fender tag
Post by moparite » Mon Apr 04, 2016 10:53 am
73'BIRD
Post by 73'BIRD » Mon Apr 04, 2016 11:33 pm
OK got it but one line confuses me:
KB5 - The provided code/year combo is currently undocumented
72 cuda repli-mod
Post by 71_bronze_gtx » Tue Apr 05, 2016 6:27 am
B5 Blue - PPG Ditzler # 2627. Renamed Lucerne Blue Poly on the paint chart. I guess colors look better if you keep renaming them every couple of years.
73'BIRD
Post by 73'BIRD » Tue Apr 05, 2016 9:00 am
71_bronze_gtx wrote:B5 Blue - PPG Ditzler # 2627. Renamed Lucerne Blue Poly on the paint chart. I guess colors look better if you keep renaming them every couple of years.
Ya that came up but the KB5 is repeated twice which results in that sentence I didnt understand
Post by ILUV72RRs » Tue Apr 05, 2016 11:44 am
The KB5 above the E24 is the car's body color. The other one above it is the top or roof color. If you have a vinyl top then this would be where that would be coded or if the car was available with a painted top, other than the body color, then the different paint code would appear in that spot. Hope this helps.
moparite
Post by moparite » Tue Apr 05, 2016 3:11 pm
Do you have the build sheet? If you look at it there are different lines witch have the same letter/# code on them as do the fender tag. It will give you a better way of understanding whats on the tag.
Moparlar
And a roadrunner clone
Post by Moparlar » Tue Apr 05, 2016 3:32 pm
Thats pretty much a Satellite With Manual Disc brakes, AM Radio, Manual Outside Mirror, Body side Moldings. 6 Cylinder, 3 Speed manual on the tree, Blue bench seat Blue paint
1971 drag car
1972 440 6pack Roadrunner
73'BIRD
Post by 73'BIRD » Wed Apr 06, 2016 8:51 am
ILUV72RRs wrote:The KB5 above the E24 is the car's body color. The other one above it is the top or roof color. If you have a vinyl top then this would be where that would be coded or if the car was available with a painted top, other than the body color, then the different paint code would appear in that spot. Hope this helps.
Ya that makes sense so if it had another code it would have meant it was two tone or had a vinyl roof.
73'BIRD
Post by 73'BIRD » Wed Apr 06, 2016 8:53 am
Moparlar wrote:Thats pretty much a Satellite With Manual Disc brakes, AM Radio, Manual Outside Mirror, Body side Moldings. 6 Cylinder, 3 Speed manual on the tree, Blue bench seat Blue paint
Thats not what it is now though. Its a 440/727 with bucket seats and no side mouldings
Post by sdweatherman » Thu Apr 07, 2016 8:10 pm
Most of the fender tag decoders on the web are for 1969-1971 cars. Most of the codes for 1972-1974 cars are the same, but several are different. I will check my book sometime tonight.
Post by sdweatherman » Fri Apr 08, 2016 12:28 am
E24 - 225 cu in Slant 6 - 1 bbl
D14 - 3 speed manual trans, column shift
KB5 - Body and Top color - Lucerne Blue Metallic
B2B6 - Vinyl bench seat - blue in color
000 - Full door panels - no trim paint required
508 - Scheduled production date - May 8th, 1974
949790 - Vehicle order number
U - Built for USA specifications
B43 - Front disc, rear drum brakes
G51 - Drivers side manual chrome mirror
R11 - AM radio (2 watt)
V5X - Black body side protective moulding
Y16 - Sales bank car
END - End of options codes
moparite
Post by moparite » Fri Apr 08, 2016 1:22 pm
by 73'BIRD on Wed Apr 06, 2016 9:01 pm
Im wondering what I should do to my 73 roadrunner. It came with a 440/727 from the factory but the engine and trans are gone.
What is the fifth digit on the vin plate on the dash? B, C, E, or T, U?
E24 is a 6 cylinder! That code was used in 72-74 Your vin code should be B C E depending on the configuration.
steved
other stuff
Post by steved » Mon Apr 11, 2016 4:10 pm
a blue on blue, disk brake, slant 6 car?
is it a 4 door?
73'BIRD
Post by 73'BIRD » Tue Apr 12, 2016 9:15 am
steved wrote:a blue on blue, disk brake, slant 6 car?
is it a 4 door?
Nope
