Installation help with air grabber decal
70 RR
My Cars: 1970 Roadrunner 440+6
Post by 70 RR » Sat Oct 03, 2015 10:27 am
I'm repainting my hood and the "R" in the word grabber is screwed up because it makes contact with the door pin and l guess it turns? Is there a cap or something missing that covers the pin? Please help, here is a picture showing my problem.
Air Grabber-1-1.jpg (16.07 KiB) Viewed 14177 times
Re: Installation help with air grabber decal
Post by 72RoadRunnerGTX » Sat Oct 03, 2015 12:59 pm
Not missing anything, that’s how it was assembled. Decal installed after the pin. Pin floats, and was necessary to cut the decal around the pin head the remove. I changed the lever pin design on my current A/G, installed a nut insert on the outside, filled the pin hole outer surface, ran a screw and sleeve in from the inside.
70 RR
Post by 70 RR » Sat Oct 03, 2015 1:53 pm
Thanks for the response, that's a great idea. I'm wondering if I put a small piece of electrical tape *just enough to cover the pin head) on the backside of the decal so it can't stick to the pin wouldn't do the trick? I'll figure it out, I'm just glad I'm not missing anything just another bad design.....
Post by 72RoadRunnerGTX » Sat Oct 03, 2015 3:16 pm
Have to consider a part of “good design” back then was to design them to be assembled as quickly as possible with no real concern about servicing or lasting more than a few years.
My old ’70 RR from back in the day:
70 RR
Post by 70 RR » Sat Oct 03, 2015 3:49 pm
You've got that right. Those are both beautiful cars!
My Cars: 71 roadrunner
Post by dangina » Sat Oct 03, 2015 7:09 pm
72RoadRunnerGTX wrote:Not missing anything, that’s how it was assembled. Decal installed after the pin. Pin floats, and was necessary to cut the decal around the pin head the remove. I changed the lever pin design on my current A/G, installed a nut insert on the outside, filled the pin hole outer surface, ran a screw and sleeve in from the inside.
what a great idea! wish I have seen this a few months ago when I put my on :(
