Hood mounted turn signals
Post by rr6pak » Sun Jun 01, 2014 5:20 pm
Does someone have a picture of the underside of the hood that shows how the wires for the hood mounted turn signals are attached to the hood? My clip is broke and need to see
Also, does the tubing for the windsheild squirters just run along the wire harness loom and come up ti the "tee" on the hood?
Thanks!
Re: Hood mounted turn signals
Post by rr6pak » Wed Jun 04, 2014 10:48 am
No one????
Ronnman
Post by Ronnman » Sat Jun 14, 2014 9:51 am
See attached thread below. If you need addition pics I can dget some, but give me some time because I just got my computer back from the repair shop.
http://www.roadrunnernest.com/forum/vie ... 416#p33416
Post by rr6pak » Sun Jun 15, 2014 7:06 am
Ronnman wrote:See attached thread below. If you need addition pics I can dget some, but give me some time because I just got my computer back from the repair shop.
Thanks Ronman! The more picture, the better. I'd like to see the clip that holds the wires against the hood and how the wires connect to the harness, if you can get them. My body guy will be done with the old girl soon.
Thanks again
Ronnman
Post by Ronnman » Sun Jun 15, 2014 11:06 am
Here's a few more pics. I have new hood wiring clips but have not installed them as of yet.
Ron
New Hood Wiring Clips
Hood Turn Signal Wire Clip A.jpg (31.66 KiB) Viewed 20031 times
Ronnman
Post by Ronnman » Sun Jun 15, 2014 11:08 am
Another of the wiring where connected to the harness.
Ron
Hood turn signal wiring connections
Hood Trun Signal Wiring (1a).jpg (128.33 KiB) Viewed 20030 times
Ronnman
Post by Ronnman » Sun Jun 15, 2014 11:11 am
Last one of wiring from turn signals and clip positions. Note one of the clips appears to have been installed in the wrong hole.
Ron
Hood Trun Signal Wiring (2a).jpg (112.24 KiB) Viewed 20029 times
Post by rr6pak » Sun Jun 15, 2014 4:17 pm
Ronman:
Where did you get the plastic clips from?
Again, thanks!
Ronnman
Post by Ronnman » Sun Jun 15, 2014 4:40 pm
R/T Specialties 570-388-1082. Item number UNP
Ron
Ronnman
Post by Ronnman » Sun Jun 15, 2014 5:05 pm
I see on R/T Specialties website it appears the number of the clips are 0876263 WIRE RETAINER HOOD TURN INDCTR, $1.00 each.
Ron
http://www.rtspecialties.net/products.asp?cat=13
Post by rr6pak » Mon Jun 16, 2014 9:44 am
Thanks a bunch! I think I need 2
