Wiper arms will not return to park position when turned off
Sanitylost
Post by Sanitylost » Tue Jan 15, 2013 9:52 am
72 RR, supposedly new 2 speed wiper motor, Turn them on they work fine, turn them off they just stop where ever they are on the windsheild... Switch? motor? :help:
JimT1971RR
My Cars: 1971 Roadrunner.
Re: Wiper arms will not return to park position when turned
Post by JimT1971RR » Tue Jan 15, 2013 11:12 pm
This is what my 71 service manual says about your problem and possible solutions.
Condition:
Motor stops in any position when instrument panel switch is truned "off".
Possible cause:
A) Motor park switch failure in the open position.
B) Open parking circuit or open field circuit.
Correction:
A) Replace motor assembly (two speed) replace park switch and gear ( variable or three speed).
B) Test continuity of blue, red, and green wiring circuit and correct as necessary.
I hope that this information is helpful.
Jim
Post by 471Magnum » Wed Jan 16, 2013 12:54 pm
Very common problem on the two speeds. Park cam is probably toast.
At last check, there were no more reman units out there. I haven't check recently though.
gary
Post by gary » Fri Jan 18, 2013 1:45 am
I have a used 2 Spd.Wiper Motor & linkage I bought years ago and do not need (I have 3 spd.) How can i bench test it ? Is it worth anything as a core? :beer:
kenny
My Cars: RM23N1G107875
Post by kenny » Sun Jan 27, 2013 12:39 am
remanufactured motors are available - cardone 40-350 should do it.
