dash lights pulse
71runnerm51
dash lights pulse
Out driving last night and I noticed the dash lights pulse, I checked the volt gauge seemed normal , It was intermitant ... of course they always get brighter the faster you go !!! loose wire?
moparite
Re: dash lights pulse
Check the rheostat. They get dirty and don't always work well.
- JosephGiannini
check your load draw to the lights the fusable link and the switch itself sounds likea amperage problem that is causing the lights to dim. if everthing is fine calculate total electrical usage amd make sure you are running the correct alternator for your needs and regulator.
A Mopar god Is dead.
1972 roadrunner.
1972 roadrunner.
