74 runner wheels
74roadrunner440
74 runner wheels
can u put 15" wheels on a 74 runner did thet come with 14" or did they also come with both mine has 14"wheels and was wondering if they wil work is the back spacing or wheel logs 5X4.5 what is it can any one help? email me a m16king@netscape.net or 701 799 9491
Re: 74 runner wheels
14" or 15" wheels would be stock size. i have 14" mag wheels - most people are "upgrading" to 15" wheels, as 14" tires are becoming less available, unless they're for a honda. yes, bolt pattern is 5 X 4.5. back spacing depends on different factors - mainly imo your side clearance for the tires - too far out and you'll rub the inner fender, too far in and you'll look goofy and maybe even rub on the frame-rails. what is it you're trying to figure out?
74roadrunner440
if i put vecor se on and go semi wide in the rear and just a little wider in front than stock tires mabe 205 or 215 will i have problems with turning or ruming in the front and rubing quarters in the rear
rears i don't think you really have to worry about. on the front, i'm sure there is more info somewhere, but i've had 24.5" tall 235/60-14s on the front as well as 26.5" tall 225/70-14s. a 205 may be a little too narrow
i run 215-60-14 on the front and 255-60-15 on the rear. both mounted on cragars and never had a problem with them rubbing on anything
