My RR resto project
- rr6pak
- My Cars: 1971 Tor-Red RR
Re: My RR resto project
I was lucky that this car had little rust to it. I did have tiny pin holes mainly behind the driver's side but hardly nothing behind the passenger, but there was. So, I replaced both of the rear 1/4 trunk extensions. Here, she is another shot of the car on the rotisserie and being delivered to my body guy
- 20131109_170729.jpg (112.34 KiB) Viewed 76190 times
- IMG_0419.JPG (137.48 KiB) Viewed 76190 times
- rr6pak
While the car is at the body shop, I restored some things. Here is the before and after of the emergency brake
- 20131227_151313.jpg (155.5 KiB) Viewed 76190 times
- 20131227_151326.jpg (148.16 KiB) Viewed 76190 times
- 20131231_001548.jpg (114.98 KiB) Viewed 76190 times
- rr6pak
Gas pedal restored
- thumbnail_20170227_171625_resized.jpg (36.85 KiB) Viewed 76190 times
- rr6pak
Here is the before and after headlights and buckets.
- Headlights1.jpg (67.73 KiB) Viewed 76189 times
- Headlights2.jpg (58.55 KiB) Viewed 76189 times
- Headlights3.jpg (100.8 KiB) Viewed 76189 times
- rr6pak
After with trim ring polished
- Headlamp bucket.jpg (23.05 KiB) Viewed 76189 times
- Headlamp retaining ring.jpg (46.26 KiB) Viewed 76189 times
- My Cars: 71 Plymouth Road Runner
We need a 'LIKE' button around here...
Lotsa good progress here through 2018, any updates? Or did it go on the "back burner"?
Thanks, Scott.
Thanks, Scott.
- rr6pak
Good to hear from you Scott. She is mostly done but have some interior to do and some odds and ends. I've had foot surgery that s***s and weight bearing. Before surgery, I had to drop the rear end because the pinion seal was leaking. I then installed a rear stabilizer bar to go with the front one. Dealing with a few mechanical issues prior as well. Seems the carb was too big and put a little smaller one on, then surgery Anyway, as soon as I can get back on her, the better.
- 20200209_114800.jpg (113.36 KiB) Viewed 71035 times
- 20200211_171846.jpg (107.82 KiB) Viewed 71035 times
- 20210316_170900.jpg (183.91 KiB) Viewed 71035 times
Whoa! Big jump in progress! Looking awesome. What did you decide engine wise on this one - I remember you posting the original 383 was long gone, but a 1969 year 383 was in its place?
- rr6pak
The 383 wasn't gone but it wasn't original. We found that out by the serial numbers. So, I had a 400 stroked out to 470 C.I. Had it dyno tested and hit 600 HP and 610 torque. The horsepower might have gone done a little because I had to switch to a little smaller carb. I guess the guy who built it put the biggets on to hit max H.P and torque. Will I need it, probably not but sure is a good conversation piece.
- #3 Rod RH (2).jpg (153.13 KiB) Viewed 71032 times
- 20140120_165311.jpg (153.63 KiB) Viewed 71032 times
- 0202181742.jpg (134.69 KiB) Viewed 71032 times
Awesome - sounds like adequate HP to me! Thanks for catching us up, and enjoy!!
- rr6pak
Thanks! I need to order the correct Rallys and new tires. The car still has 0 miles and still on the same tires and rims from when my dad got them and put them on 30 years ago.
