Pix resizing
Pix resizing
Post by rr6pak » Sat Dec 19, 2015 11:47 am
How do you re-size pix? I must be getting Alzheimer's or something. Or should I post a link to Photobucket?
Re: Pix resizing
Post by sdweatherman » Tue Dec 22, 2015 1:54 am
The photobucket or equivalent photo hosting site is the way to go here. If you want to try the resize thing, I use Paint.net as my photo editor. It is free to download from the web and works pretty good.
Re: Pix resizing
Post by rr6pak » Sun Feb 28, 2016 1:33 pm
sdweatherman wrote:The photobucket or equivalent photo hosting site is the way to go here. If you want to try the resize thing, I use Paint.net as my photo editor. It is free to download from the web and works pretty good.
Googled it Scott but nothing. I'd like to re-size some of my pictures and save them to post here. Any help from anyone is appreciated. It's irritating as all heck :( Even played with photobucket but still gets a pop up window that won't allow me to re-size
Re: Pix resizing
Post by moparite » Fri Mar 04, 2016 9:26 am
Did you sign up? I think you need an account do use it. After you post a pic you can edit it. If you use paint you can resize it before you post to any pic hosting site. It may hep to say what you are using? Computer, tablet, phone etc...
Re: Pix resizing
Post by rr6pak » Fri Mar 04, 2016 2:03 pm
moparite wrote:Did you sign up? I think you need an account do use it. After you post a pic you can edit it. If you use paint you can resize it before you post to any pic hosting site. It may hep to say what you are using? Computer, tablet, phone etc...
I do have an account. Tried to re-size a picture off of my computer but when I put in the values, under the limit, it wouldn't let me. IDK
Re: Pix resizing
Post by moparite » Fri Mar 04, 2016 9:05 pm
Go into paint and open the pic, Click on resize. Then click on pixels then set the larger of the two #'s to around 600(this depends on the original size of the pic), Then open the drop down menu and click save as jpeg. You will have to rename it. On photobucket open the pic (large view) then click on resize at the top.
Re: Pix resizing
Post by sdweatherman » Sun Mar 06, 2016 2:34 am
Yep, you can use Microsoft Paint that is already on your computer to resize pictures. It is located in the All Programs, Accessories folder. Scott.
Re: Pix resizing
Post by rr6pak » Tue Mar 08, 2016 1:20 pm
I'll give it a whirl. Does anyone know the pixel limit to post here? Thanks for the help!
Re: Pix resizing
Post by sdweatherman » Thu Mar 10, 2016 2:02 am
I usually reduce my pictures to 640 x 480. It might cut a little off the edge, but not much.
Re: Pix resizing
Post by rr6pak » Thu Mar 10, 2016 10:12 am
sdweatherman wrote:I usually reduce my pictures to 640 x 480. It might cut a little off the edge, but not much.
Thanks Scott and to all. Now, maybe I can post some pictures
