Accelerator cable removal
Posted: Wed Oct 16, 2013 2:07 pm
by rr6pak
How does the plastic plug comes out of the firewall without breaking? Is it repoped in case?
Re: Accelerator cable removal
Posted: Fri Oct 18, 2013 11:00 am
by rr6pak
Anyone? I just dont want to end up breaking the plug because not sure if its repopped. There was a piece of metal, like a n=broken cotter pin, at the top that I removed. Then there's some tabs on the left and right of the block. I thought it needed to be squeezed together and that would release it but no. Am I on the right track?
Posted: Fri Oct 18, 2013 12:39 pm
by bruce
Yes, they are reproduced, but in my case it came with the new throttle cable for my 6 BBL set up. So unfortunately I can't point you to where you might find them. Sorry!
Posted: Fri Oct 18, 2013 1:36 pm
by rr6pak
bruce wrote:Yes, they are reproduced, but in my case it came with the new throttle cable for my 6 BBL set up. So unfortunately I can't point you to where you might find them. Sorry!
Do you know who has the bbest quality Bruce. My motor is coming sokn and I want to get the correct cable if I accidently break the old ok ne. Thanks
Man, I feel like a tard when I saw the typing. That's what happends when tying on the phone and not seeing real good. Glasses?...lol
Posted: Fri Oct 18, 2013 2:18 pm
by Gotgrey
Just squeeze the tabs under the dash on the plastic while pushing out. Hardest part is getting under there and the proper tool. small pair of channel locks
