Page 32 of 35
Posted: Sun May 28, 2023 7:42 pm
by 71Beeper
Posted: Sun May 28, 2023 7:44 pm
by 71Beeper
Posted: Sat Jun 10, 2023 9:49 am
by sdweatherman
This car is going to be a stunner when you are done with it!!! Hope to get back working on mine by mid July.
Posted: Sun Jun 11, 2023 4:40 pm
by 71Beeper
Thanks Scott,
Yes, my list of things to do on the car is getting a little shorter.
Yesterday was the nerve racking day to drill holes in the trunk lid for the gull wing.
But first I had to put the wing together.
The first hiccup - the adjustment plate and the hole in the pedestal were slightly off.
I went to put the bolt in and it started going in fur-cocked......
- June 8th (4).jpg (71.22 KiB) Viewed 230496 times
- June 8th (3).jpg (67.33 KiB) Viewed 230496 times
So I had to take a Dremel and open up the slot.
Here's the before and after shot.
- June 8th (5).jpg (88.07 KiB) Viewed 230496 times
Then give them a coat of the SEM landau black.
Next is put everything together and on the wing.
- June 11th (2).jpg (62.93 KiB) Viewed 230496 times
- June 11th (3).jpg (61.57 KiB) Viewed 230496 times
Posted: Sun Jun 11, 2023 4:43 pm
by 71Beeper
Posted: Sun Jun 11, 2023 4:48 pm
by 71Beeper
Next - I held the wing in place and had my assistant (wife) draw around the stud holes.
That would be the final location for the holes.
- June 11th (10).jpg (49.04 KiB) Viewed 230495 times
Then say a prayer and get out the drill.
Starting with a very small starter hole, then move up in sizes.
The final hole size is 5/16".
Now put the studs thru the holes to check.
- June 11th (11).jpg (73.88 KiB) Viewed 230495 times
- June 11th (12).jpg (81.37 KiB) Viewed 230495 times
- June 11th (13).jpg (88.78 KiB) Viewed 230495 times
It fits!!!
Posted: Sun Jun 11, 2023 4:53 pm
by 71Beeper
Now to remove the tape from the topside and get started on the underside.
- June 11th (17).jpg (55.86 KiB) Viewed 230495 times
When I drilled the topside holes I went all the way thru the ribbing on the underside.
Then I used a step drill to get the hole big enough for the flanged nuts to go thru.
- June 11th (18).jpg (76.8 KiB) Viewed 230495 times
For the reinforcement plate that gets mounted to the underside I used stainless riv-nuts for the fasteners.
- June 11th (19).jpg (100.19 KiB) Viewed 230495 times
Then install the plates and button it up.
- June 11th (21).jpg (61.59 KiB) Viewed 230495 times
Here's the final look - Man am I relieved that's over...
- June 11th (22).jpg (83.97 KiB) Viewed 230495 times
Posted: Sat Jun 24, 2023 3:22 pm
by 71Beeper
With that big task out of the way, it's back to working on the engine.
First order of business is to remove the inner valve springs.
- June 11th (14).jpg (144.37 KiB) Viewed 230381 times
- June 11th (15).jpg (127.71 KiB) Viewed 230381 times
- June 11th (16).jpg (106.76 KiB) Viewed 230381 times
Then get the timing cover installed.
- June 15th.jpg (82.94 KiB) Viewed 230381 times
And now put the Romac harmonic balancer on.
- June 20th (3).jpg (85.64 KiB) Viewed 230381 times
Posted: Sat Jun 24, 2023 3:24 pm
by 71Beeper
Next - I installed some magnets in the lifter valley.
8 magnets in total.
My engine does this with all the roundy round engines he builds - makes them live longer.
- June 20th (1).jpg (144.89 KiB) Viewed 230381 times
- June 20th (2).jpg (154.43 KiB) Viewed 230381 times
Posted: Sat Jun 24, 2023 3:26 pm
by 71Beeper
Posted: Thu Jul 06, 2023 8:12 pm
by 71Beeper
I finally got the rest of the engine bits back on it.
All there is left is the valve covers & alternator and fan.
Oh, don't forget headers and carb along with distributor.
- July 6th (3).jpg (138.19 KiB) Viewed 230255 times
- July 6th (4).jpg (140.59 KiB) Viewed 230255 times
- July 6th (2).jpg (144.78 KiB) Viewed 230255 times
Soon enough I'll be able to put it on the K-member and get the headers mounted along with bellhousing, clutch & starter.
Posted: Thu Jul 06, 2023 8:30 pm
by 71Beeper
I was finally able to score the most sought after part for this project...........the coveted dash pad..
I'd been searching for a replacement pad for about 2 years now as the one that came in the car was had the typical cracks on it.
- July 3rd (12).jpg (74.34 KiB) Viewed 230254 times
- July 3rd (13).jpg (58.23 KiB) Viewed 230254 times
A little backstory on this crusade.
I had an order for one with a company called Moparts Canada located in Windsor, Ontario.
Well after dickin me around for a year they still could not come up with one, so I cancelled my order.
A local Mopar guy was getting them from a company in El Paso, Texas (but wouldn't tell me the name of said company) so I had him order one for me - that was in March of this year.
I heard nothing about mine until recently I messaged him and he said that he cancelled all his orders and stopped payment.
So I asked about my order to which the reply was "sorry, I might go to Carlisle and find one."
So I figured my chances of him finding one was a snowballs chance in he!!
Last week I was looking on the for B-Bodies site under interior parts for sale and lo & behold there's a dash pad for sale!!!
Long story short I made contact with the seller who agreed to ship it to my US mailbox.
I picked it up on July 3rd.
I couldn't be happier...
- July 3rd (1).jpg (81.51 KiB) Viewed 230254 times
- Dash pad pics (12).jpg (83.67 KiB) Viewed 230254 times
- July 3rd (2).jpg (109.9 KiB) Viewed 230254 times
Posted: Thu Jul 06, 2023 8:37 pm
by 71Beeper
Along with the dash pad which was done by ABC Moparts I also got a complete set of ducting for an A/C setup.
I also got a speaker grille and under dash fasten seat belt / map light panel.
Today I finally got the chance to try it on the frame.
It fits great!
- July 6th (15).jpg (100.08 KiB) Viewed 230254 times
- July 6th (13).jpg (116.56 KiB) Viewed 230254 times
A little hint to getting a great fit - don't use the speed nuts that are normally used to fasten the dash to the frame, instead use #10-24 ny-loks like I did along with #10 fender washers.
- July 6th (6).jpg (68.38 KiB) Viewed 230254 times
- July 6th (7).jpg (55.81 KiB) Viewed 230254 times
- July 6th (11).jpg (82.25 KiB) Viewed 230254 times
Posted: Sat Jul 08, 2023 4:08 pm
by 71Beeper
Well guys, I've waited a long time for this.
I was finally able to install the complete dash assembly into the car.
- July 8th (10).jpg (89.72 KiB) Viewed 230239 times
- July 8th (11).jpg (101.44 KiB) Viewed 230239 times
- July 8th (12).jpg (104 KiB) Viewed 230239 times
And got the bulkhead connectors attached.
- July 8th (13).jpg (94.58 KiB) Viewed 230239 times
- July 8th (14).jpg (78.93 KiB) Viewed 230239 times
It's been a big hurdle for me.
Not I can celebrate with a
Now I can prepare for the engine install.
Posted: Sun Jul 23, 2023 3:13 pm
by 71Beeper
Back to doing more work.
Dug out the front bumper.
- July 22nd (1).jpg (103.72 KiB) Viewed 230090 times
Time to get some primer on the underside of it.
- July 22nd (6).jpg (103.97 KiB) Viewed 230089 times
And 2 coats of white paint to protect it.
- July 23rd (8).jpg (108.68 KiB) Viewed 230090 times
