Page 31 of 35
Posted: Sun Mar 05, 2023 12:43 pm
by 71Beeper
Got in the shop this morning - the paint is almost dry.
Still tacky in a few places.
Here's what semi-gloss black looks like.
- March 5th 2023.jpg (121.19 KiB) Viewed 241488 times
Next thing to clean-up is the upper and lower control arms & strut rods.
Posted: Fri Mar 10, 2023 1:04 am
by 73X
Looking nice!
Posted: Sun Mar 26, 2023 3:03 pm
by 71Beeper
Thanks 73X.
Next step is do paint the control arms. The current aluminum color that's on them need some freshening up.
I scuffed them down and applied a light grey paint to them.
- March 12th (5).jpg (94.04 KiB) Viewed 241415 times
- March 12th (6).jpg (76.35 KiB) Viewed 241415 times
- March 12th (7).jpg (64.71 KiB) Viewed 241415 times
- March 12th (4).jpg (109.67 KiB) Viewed 241415 times
- March 12th (1).jpg (116.16 KiB) Viewed 241415 times
Future plans call for changing the upper arms for some tubular ones.
Posted: Sun Mar 26, 2023 3:09 pm
by 71Beeper
Moving along, the strut rods are next.
Scuff em down and paint them with a nice steel color VHT caliper paint.
Also put new stainless hardware on the ends.
- March 26th (1).jpg (107.66 KiB) Viewed 241415 times
- March 26th (2).jpg (61.05 KiB) Viewed 241415 times
- March 26th (4).jpg (43 KiB) Viewed 241415 times
Posted: Sun Mar 26, 2023 3:13 pm
by 71Beeper
Now its on to prepping the steering components.
Scuff them down with my fiber wheel.
Wash them up with lacquer thinner & do some masking too.
- March 26th (11).jpg (103.05 KiB) Viewed 241415 times
- March 26th (12).jpg (114.16 KiB) Viewed 241415 times
- March 26th (13).jpg (119.67 KiB) Viewed 241415 times
- March 26th (14).jpg (116.72 KiB) Viewed 241415 times
- March 26th (15).jpg (101.59 KiB) Viewed 241415 times
I'll do 2 coats of primer followed by the same VHT caliper steel colored caliper paint.
Posted: Mon Apr 10, 2023 8:04 pm
by 71Beeper
Posted: Mon Apr 10, 2023 8:06 pm
by 71Beeper
I did remove the old hardware that was on the tie-rod sleeve clamps.
- April 10th (4).jpg (119.71 KiB) Viewed 241331 times
Not going to re-use those.
Instead I bought these.
- April 10th (3).jpg (108.92 KiB) Viewed 241331 times
They will look much better.
Posted: Mon Apr 10, 2023 8:08 pm
by 71Beeper
Posted: Mon Apr 10, 2023 8:11 pm
by 71Beeper
Posted: Thu Apr 13, 2023 1:42 am
by 73X
The white looks awesome!
Posted: Sun Apr 23, 2023 8:09 pm
by 71Beeper
Thanks 73X - I'm liking it more & more every time I see it.
So I finally was able to get the tailstock on my 4 speed changed.
If you remember the shifter box mounting holes were damaged when I bought the 4 speed.
- Feb 26th (4).jpg (91.68 KiB) Viewed 241238 times
And I was able to find a good replacement tailstock.
- Feb 23rd (3).jpg (100.33 KiB) Viewed 241238 times
So, after ordering the correct gasket kit from Brewers I took the 4 speed to my good buddy Kevin's place to get it switched.
Here it is on the bench ready to go back together again.
- April 22nd (4).jpg (114.64 KiB) Viewed 241238 times
Here's a look at the internals - Kevin said it was in great shape.
- April 22nd (2).jpg (90.97 KiB) Viewed 241238 times
And here it is back together again waiting for me to pick it up.
- April 22nd (1).jpg (94.57 KiB) Viewed 241238 times
Posted: Sun Apr 23, 2023 8:11 pm
by 71Beeper
Oh, I forgot to mention, he did change out the bushing in the tailstock as well.
- April 22nd (3).jpg (58.22 KiB) Viewed 241238 times
Here it is back home.
- April 21st (1).jpg (87.38 KiB) Viewed 241238 times
Next step is to prep and paint it.
Posted: Sun May 07, 2023 11:37 am
by 71Beeper
My buddy who assembled my engine, Brad came over yesterday and degreed the new Isky cam.
It was installed straight up as it already has 4 degrees of advance ground into it.
- May 6th (2).jpg (146.67 KiB) Viewed 241135 times
- May 6th (3).jpg (90.92 KiB) Viewed 241135 times
- May 6th (4).jpg (87.34 KiB) Viewed 241135 times
Here's the cam info.
- Isky cam info.jpg (77.7 KiB) Viewed 241135 times
I will be going with Harland Sharpe 1.6 roller rockers.
- April 16th, 2023 (5).jpg (116.91 KiB) Viewed 241135 times
Posted: Thu May 18, 2023 7:30 pm
by 71Beeper
Posted: Tue May 23, 2023 9:24 am
by 71Beeper
I did some horse trading and managed to get a gull wing.
- May 22nd (5).jpg (87.72 KiB) Viewed 240926 times
But, the mounting brackets are broken.
- May 22nd (8).jpg (65.93 KiB) Viewed 240926 times
Probably due to the fact the mounting surface was not flat...you can see the reinforcement plates and the screw heads are not flush.
- May 22nd (6).jpg (50.14 KiB) Viewed 240926 times
I've got new pedestals and mounting plates on order with Dante's.
And the corner tips need a bit of putty and clean-up.
- May 22nd (9).jpg (49.89 KiB) Viewed 240926 times
- May 22nd (10).jpg (30.34 KiB) Viewed 240926 times
