Page 27 of 35
Posted: Sun Jan 30, 2022 6:20 pm
by 71Beeper
Posted: Sun Jan 30, 2022 6:23 pm
by 71Beeper
I also installed the rear seatbelts.
- Jan 30th (7).jpg (182.43 KiB) Viewed 85288 times
It's nice that the car is finally starting to have some contrasting color on it.
- Jan 30th (9).jpg (74.37 KiB) Viewed 85288 times
- Jan 30th (10).jpg (74.56 KiB) Viewed 85288 times
Posted: Sun Feb 06, 2022 5:17 pm
by 71Beeper
Posted: Mon Feb 21, 2022 4:26 pm
by 71Beeper
So continuing on with the carpet install, I had time to put in the front section.
- Feb 21st (11).jpg (110.92 KiB) Viewed 85100 times
Of course I had to add some weights to flatten it some.....
- Feb 21st (12).jpg (144.56 KiB) Viewed 85100 times
Posted: Mon Feb 21, 2022 4:31 pm
by 71Beeper
Next step.....I dug the dash frame out of storage and took some photos before I start to take it apart.
- Feb 19th (5).jpg (111.55 KiB) Viewed 85100 times
Yup, the dash pad is beat to crap....
- Feb 19th (17).jpg (82.34 KiB) Viewed 85100 times
- Feb 19th (18).jpg (71.38 KiB) Viewed 85100 times
Started cleaning up the underside of the speaker cover....
- Feb 20th (5).jpg (93.42 KiB) Viewed 85100 times
And start on the underside of the dash frame as it left the factory with no paint. Good thing mine only has surface rust.
- Feb 20th (9).jpg (113.23 KiB) Viewed 85100 times
Posted: Mon Feb 21, 2022 4:47 pm
by 71Beeper
Posted: Wed Feb 23, 2022 11:46 am
by sdweatherman
Loving it! Still too cold in SD to do anything on my ride. I was just going through some of my registry files, and its kinda funny that the three of us (you, me, and ct71RR) that are posting progress on our cars, all 3 of them are GY8 gold cars. Keep the progress going!
Posted: Mon Feb 28, 2022 9:37 pm
by 71Beeper
I love the sound of that Scott...
But as I get closer to finishing mine I've realized that the rest of the parts I need to finish mine will all be in the $500 and up range.
Dash pad = at least $550 US
Rear glass = $510 CDN
Diaphragm clutch = at least $500 or more CDN
Complete exhaust = at least $500 CDN
Engine break-in = $600 CDN
Is it discouraging??? a little, but I'm not letting that stop me.
So in the meantime I keep going.
On the weekend I was able to borrow a steamer from my work.
- Feb 27th (10).jpg (140.86 KiB) Viewed 85029 times
So I can put some steam on the carpet to get it to lay flat.
- Feb 27th (6).jpg (63.15 KiB) Viewed 85029 times
Took a bit of effort....
- Feb 27th (5).jpg (116.14 KiB) Viewed 85029 times
But all in all it turned out just fine.
I trimmed up the edges where the sill plates go too.
I did use some Alien Tape on the 4 spd hump to keep the carpet molded properly.
- Feb 27th (9).jpg (130.32 KiB) Viewed 85029 times
- Feb 27th (8).jpg (121.09 KiB) Viewed 85029 times
Posted: Tue Mar 01, 2022 1:58 pm
by ct71rr
Looks great! What was giving you trouble with the lower door panels?
Posted: Wed Mar 02, 2022 8:25 pm
by 71Beeper
ct - the trouble I had with the lower door panels were the clips.
I bought brand new clips from a Mopar guy up here in Ontario.
The issue was when I started on one nd of the door with the installation.....by the time I got to the other end the clips were nowhere near their respective holes that they had to go into....
So I had to remove all of them and start over.
In addition to that, you know what the end of the clip looks like right?
- Door clips.jpg (14.91 KiB) Viewed 84996 times
If you don't get the crossed end into the hole completely, it won't stay in place.
A couple of them I had only one of the ends in the hole while the other was beside the hole and when I slammed against the panel and it didn't stay in place, I pried between the door and panel to see the clip bent like a pretzel.
I'm makin it sound worse than it really was....
I guess I learned something because the upper panels went in easier......maybe because I knew what to look for.
Posted: Sun Mar 06, 2022 9:13 pm
by 71Beeper
Posted: Sun Mar 06, 2022 9:14 pm
by 71Beeper
Posted: Sun Mar 13, 2022 3:28 pm
by 71Beeper
Posted: Sun Mar 20, 2022 5:43 pm
by 71Beeper
Posted: Sun Apr 03, 2022 2:48 pm
by 71Beeper
Got the steering column apart.
First is to get the main shaft out.
- March 27th (1).jpg (146.91 KiB) Viewed 84498 times
Here are some of the bits.
- March 27th (2).jpg (148.29 KiB) Viewed 84498 times
Then clean up the main shaft.
- March 27th (3).jpg (124.63 KiB) Viewed 84498 times
I have a power steering column that came out of the car. I will be taking the mounting plates from it to use on this manual steering column.
- March 27th (4).jpg (95.61 KiB) Viewed 84498 times
