Page 5 of 8
Re: sorta new
Posted: Sun Apr 25, 2021 7:31 pm
by 71440 gtx
Do you doing the most awesome job and I respect and I'm watching you you're saving an old toy awesome
Re: sorta new
Posted: Mon Apr 26, 2021 3:25 pm
by ct71rr
Thank you
Re: sorta new
Posted: Sun May 02, 2021 10:14 am
by ct71rr
I got the flange located at the lower front side of the right wheelhouse replaced. Thank you
Scott for the pictures! While doing so, I found that the AMD replacement outer wheelhouse does not have the recess at the bottom front to accommodate the flange. The original flange, as you can see from Scotts images, also steps in to accommodate the recess in the outer wheelhouse. Because this recess is not in the AMD panel, I made my patch flat. I also patched in the bottom corner of the right side door pillar. This area was rotted.
Scott’s picture showing the step in the flange and recessed area in outer wheelhouse:
- 8D54CBEC-3F59-4D81-827B-81D32427AEAE.jpeg (196.64 KiB) Viewed 226284 times
My original, what was left of it anyway:
- 3D2C3458-0A14-42F6-BA97-9AFA8971E01B.jpeg (155.03 KiB) Viewed 226284 times
Template:
- 8AFE8B66-61FD-46FB-8A6F-FEA348CA3A68.jpeg (117.98 KiB) Viewed 226284 times
Mocked in:
- B84AEBED-E53D-43DF-9E27-CA774A8661B4.jpeg (131.81 KiB) Viewed 226284 times
Welded in:
- EACF869A-2C09-42FB-9001-8EED8BFB2456.jpeg (138.11 KiB) Viewed 226284 times
Re: sorta new
Posted: Sun May 02, 2021 10:15 am
by ct71rr
This is the area of the lower corner of the door pillar. I still need to touch up a few spots with the mig:
- 7D367461-CB95-41AF-8D5E-000DBCB474DC.jpeg (160.92 KiB) Viewed 226284 times
Re: sorta new
Posted: Sun May 30, 2021 9:01 am
by ct71rr
Started to work on getting the trunk pan in.
Test fit:
- D4E24CE1-702C-4096-B91F-CE11337533CD.jpeg (177.58 KiB) Viewed 226165 times
Traced out rail locations for plug weld holes:
- 4AC84F1E-9E3B-45C0-A99D-7C968C759BB4.jpeg (128.15 KiB) Viewed 226165 times
Welded on braces:
- 0BF5366B-2E1F-471B-9FB9-76048EC72161.jpeg (116.8 KiB) Viewed 226165 times
And then I ran out of shield gas
Re: sorta new
Posted: Sun May 30, 2021 9:03 am
by ct71rr
I also blasted and primed the donor rear section of the trunk. I still need to remove a few pieces off of it that I don’t need.
Donor piece:
- 8DB258CD-786C-438B-B194-1EA15CB7DF3D.jpeg (408.62 KiB) Viewed 226165 times
After blasting:
- 8695CDF7-CF56-4FC8-AD7D-BC206711A00B.jpeg (210.26 KiB) Viewed 226165 times
In primer:
- A8648D5D-3BDC-48BA-B80F-219B118A1DAA.jpeg (160.28 KiB) Viewed 226165 times
Re: sorta new
Posted: Sat Jun 12, 2021 6:30 pm
by ct71rr
Re: sorta new
Posted: Sat Jun 19, 2021 12:25 pm
by gary
Re: sorta new
Posted: Sun Jun 20, 2021 9:39 am
by sdweatherman
Wow, lots of work! Keep it going!
Re: sorta new
Posted: Sun Jun 20, 2021 9:17 pm
by 71Beeper
I bought those same pieces for mine CT, but I had the body shop install them when they put the new quarters on...
Re: sorta new
Posted: Mon Jun 28, 2021 9:13 pm
by ct71rr
Re: sorta new
Posted: Sun Jul 04, 2021 10:03 pm
by sdweatherman
Yes! Mock up everything with sheet metal screws or a few very tiny weld tacks. Make sure everything fits good and all the gaps are good before doing any final welding. Looks great so far!
Re: sorta new
Posted: Fri Jul 09, 2021 8:31 am
by 71440 gtx
Re: sorta new
Posted: Sun Feb 27, 2022 3:58 pm
by ct71rr
Re: sorta new
Posted: Sun Feb 27, 2022 3:59 pm
by ct71rr
- C2DA4342-D1B8-419C-A395-041535E0727D.jpeg (148.89 KiB) Viewed 222885 times
- A8926200-BA76-441B-BCF5-307CBAB7897C.jpeg (128.93 KiB) Viewed 222885 times
