STROBE STRIPE
Re: STROBE STRIPE
Post by Eric » Mon Aug 24, 2009 12:21 pm
Thunderstruck440 wrote: I believe the stripe I bought came as a 3-piece.
For a closer alignment, you can use a tape measure to check how low the stripe is on the wheel openings for the sides. For the top, you can measure to the back window to the stripe. Masking tape is a big help to make sure your angles are right.
I did the top first, how well you center it will give the results of the sides.
The paper over the stripe should stay on, that will protect the edges while you squeegee and keep all the individual squares together. Just be sure to use lots of that soapy water!
X2....do the top/center stripe first. Measure to the center of your roof, mark with a small piece of tape. Also mark your stripe center (on the carrier paper). Tape one side of the stripe carrier paper down with masking tape. Then tape the side stripes to the center stripe (again, tape the carrier paper) in the correct spacing. This will allow you to align the stripe correctly over the wheel wells. When you have it placed correctly, tape down the one side of the center stripe in the final location and remove the side stripes. Now you have it in the correct location ready to install.
I use glass cleaner in a spray bottle instead of soapy water. Either way works.
BuckNeccid
Re: STROBE STRIPE
Post by BuckNeccid » Tue Aug 25, 2009 8:28 am
ARI440 wrote:I have no air filter on yet ,its very close to the hood
working on an AIR GRABBER hood ,so it will be able to use an air filter
looking to get a 1050 dominater to fit on an ovel air cleaner
the moter : 446 ci 12.5 comp 585/255 solid cam stage 4 ported heads ported M1 and a 750
5000 stall 727 manual valve body 8 3/4 .... 4.10 gears
Do you already have an air grabber for it, or are you looking? If you're looking, I have an almost complete setup from Stinger Fiberglass I'm not going to use. Bubble, scoop, hinge, door actuator, underhood air box, stainless studs rubber seal, and the correct factory air cleaner for a 440. I have about $1100 in it all, and I'll take $750 for it. Also have a flat hood to cut to put it on if you want to pick it up.
I'm in South Point, OH, right where WV/OH/KY come together, and about 3 miles off I-64 in WV, there's 3 blocks of city streets to drive once you're off the 4 lane
Re: STROBE STRIPE
Post by Smellslike1974 » Tue Aug 25, 2009 1:12 pm
bruce wrote:
ARI440 wrote:THANKS
I got major wood here! :beer:
:haha: and IM the weird one.
That is nice though.
Re: STROBE STRIPE
Post by bruce » Tue Aug 25, 2009 1:29 pm
Smellslike1974 wrote:
bruce wrote:
ARI440 wrote:THANKS
Admit it, you just want to LICK it... :lol:
Diriccatiticka
Re: STROBE STRIPE
Post by Diriccatiticka » Tue Aug 25, 2009 2:08 pm
I guess that thing's pretty much all race with a 5000 stall. Extreme!
I have a 3500+ in mine, and I try to drive it at least once a week on the street to local shows.
Sweet though!
'72 Road Runner
ARI440
Re: STROBE STRIPE
Post by ARI440 » Tue Aug 25, 2009 10:10 pm
this is the moter thats in the road runner now
detuned from what it was and a pic of my 72 duster
ARI440
Re: STROBE STRIPE
Post by ARI440 » Tue Aug 25, 2009 10:15 pm
for now im looking to get the bubble ,dont have a lot to spend
if you want to sell only the bubble , PLEASE let me know
im from new york , long island , nassau county
THANK YOU FOR THE OFFER :beer:
ARI440
Re: STROBE STRIPE
Post by ARI440 » Tue Aug 25, 2009 10:17 pm
511 CI
INDY SR,S 650/280 solid cam
this is whats in the duster now
