- ct71rr
You’re almost getting as bad as me with updates
Ugh, I know!
Re: Daddy's Stinky Car progress page - updated for 2022-23.
Alright - I did get a little work done back in 2022. But 2023 was no bueno - other than some very basic sorting and cleaning of hardware. Here are a few pictures of progress on the passenger side of the car. I did manage to score an AVS2 for the suped up 318.
Re: Daddy's Stinky Car progress page - updated for 2024.
Progress for 2024!!! While it's still a bit chilly and wet to do bodywork, I figured I would work on one of the bling items on my 1971 Satellite. Here are some pics of the Rallye Gauge cluster getting a basic restoration. I cleaned up the bezel and applied some fresh argent silver along the edges. I applied some fresh bright white paint to the gauge housing. I repainted the orange needles, since they had faded a bit. I had to create my own foam gaskets, as the old ones were deteriorated. And I had to repair the upper left screw hole in the bezel with a little JB plastic weld. Pretty happy with the end result.
Going to try real hard to keep at it this year!!
- My Cars: 1971 Satellite
Great work on the cluster Scott!
- ct71rr
Yes, the cluster came out really nice!
Been a busy summer once again, but found some time to restore some small components - grill brackets and some other misc front end brackets.
- P20240923_1927_web.jpg (103.58 KiB) Viewed 48385 times
Scott, are you going with LED bulbs in the dash cluster?
I haven't given it much thought, but I will probably go that direction - along with LED tail lights.
Re: Daddy's Stinky Car progress page - updated for 2025.
Alright, car was getting lonely again. So after all the summer fun, I promised her I would give her a little attention. With most of the bodywork completed in the engine bay and the interior, it was time to get those areas cleaned up and primed. Then a little seam sealer was in order in the areas that had hardened and crumbled away. Then it was on to some FINAL GY8 paint for these areas. I just might be able to start bolting on some additional parts!!!! I have some hood hinges, a battery tray, and inner fender access plates and splash shields that need to go on!!!
- P20250913_1558_web.jpg (84.45 KiB) Viewed 4779 times
- P20250913_1805_web.jpg (106.04 KiB) Viewed 4779 times
- P20251019_1711_web.jpg (131.26 KiB) Viewed 4779 times
- P20251019_1712_web.jpg (135.19 KiB) Viewed 4779 times
- P20251019_1752_web.jpg (76.57 KiB) Viewed 4779 times
- P20251019_1753_web.jpg (97.92 KiB) Viewed 4779 times
- P20251022_1753_web.jpg (74.22 KiB) Viewed 4779 times
- P20251022_1754_web.jpg (79.16 KiB) Viewed 4779 times
- P20251022_1756_web.jpg (61.8 KiB) Viewed 4779 times
And finally - the GY8 paint!!!
- P20251101_1232_web.jpg (92.21 KiB) Viewed 4778 times
- P20251102_1119_web.jpg (131.4 KiB) Viewed 4778 times
- P20251102_1120_web.jpg (108.5 KiB) Viewed 4778 times
- P20251104_1628_web.jpg (82.7 KiB) Viewed 4778 times
- P20251104_1633_web.jpg (138.34 KiB) Viewed 4778 times
- P20251104_1635_web.jpg (111.67 KiB) Viewed 4778 times
- P20251104_1637_web.jpg (100.55 KiB) Viewed 4778 times
- P20251104_1638_web.jpg (90.67 KiB) Viewed 4778 times
- P20251104_1640_web.jpg (110.19 KiB) Viewed 4778 times
Now I see what mine would have looked like if I kept it the original color....
DixieSatellite
Looking good - nice to see another car coming back
