sorta new
Re: sorta new
Post by sdweatherman » Mon Feb 28, 2022 5:40 pm
Nice work! Keep the updates coming!
Re: sorta new
Post by 71Beeper » Mon Feb 28, 2022 9:26 pm
CT.......a ton of work done by you so far - Kudos to you! :beer:
Keep going...
ct71rr
Re: sorta new
Post by ct71rr » Tue Mar 01, 2022 1:59 pm
Thanks sdweatherman and 71beeper! I’m finally starting to think that there’s some light at the end of the tunnel. :beer:
ct71rr
Re: sorta new
Post by ct71rr » Tue Mar 01, 2022 9:29 pm
After work, I was able to spray a few coats of Lizard Skin on the inside of my quarters.
ct71rr
Re: sorta new
Post by ct71rr » Sat Mar 05, 2022 6:12 pm
I got the quarters welded in today!!!!!! :beer: I still need to grind the plug welds though :( ...
Re: sorta new
Post by 71Beeper » Sun Mar 06, 2022 9:07 pm
Excellent job ct!
ct71rr
Re: sorta new
Post by ct71rr » Sat Mar 12, 2022 9:45 am
Excellent job ct!
Thank you :beer:
ct71rr
Re: sorta new
Post by ct71rr » Sat Apr 30, 2022 6:07 pm
Cowl is in. I sprayed the back side and top of firewall with epoxy before welding it in. I also sprayed the inner fender supports with epoxy before welding them in. I also had to add about a 1/4” to each hood hinge mount so that they fit against the cowl and kept the original measurements.
ct71rr
Re: sorta new
Post by ct71rr » Sat Apr 30, 2022 6:08 pm
More pics:
Re: sorta new
Post by sdweatherman » Sat Apr 30, 2022 10:28 pm
A lot of crazy awesome work going on here! Hopefully I can get back on mine before too long.
gary
Re: sorta new
Post by gary » Sun May 01, 2022 12:08 pm
ct71rr
Re: sorta new
Post by ct71rr » Mon May 02, 2022 1:35 pm
Thanks! And yes, crazy is the word for it!! :beer:
Re: sorta new
Post by 71Beeper » Sun May 15, 2022 7:58 pm
She's gonna be better than mine when you are done with it..... :beer:
ct71rr
Re: sorta new
Post by ct71rr » Mon May 30, 2022 10:37 am
I’m still plugging along. I replaced both end caps and a section of the driver’s side outer rocker. The end caps are not reproduced so I had to fabricate my own. I also ended up replacing the passenger’s side lower splash shield as mine was dented pretty bad. I tired fixing it but no luck. I took a gamble on the AMD E-Body replacement part as it looked pretty close to mine. Turns out, they are almost identical. I had to add some material to the top flange as it was a bit short and tapered off from right to left. I also replaced the lower radiator support with an AMD piece. I had to add the flanges that mount to the inside of the frame rails as these are missing from the AMD part.
ct71rr
Re: sorta new
Post by ct71rr » Mon May 30, 2022 10:38 am
