My RR resto project
Re: My RR resto project
Post by rr6pak » Tue Aug 14, 2018 9:45 am
I was lucky that this car had little rust to it. I did have tiny pin holes mainly behind the driver's side but hardly nothing behind the passenger, but there was. So, I replaced both of the rear 1/4 trunk extensions. Here, she is another shot of the car on the rotisserie and being delivered to my body guy
Post by rr6pak » Tue Aug 14, 2018 9:49 am
While the car is at the body shop, I restored some things. Here is the before and after of the emergency brake
Post by rr6pak » Tue Aug 14, 2018 9:54 am
Gas pedal restored
Post by rr6pak » Tue Aug 14, 2018 12:28 pm
Here is the before and after headlights and buckets.
Post by rr6pak » Tue Aug 14, 2018 12:37 pm
After with trim ring polished
Headlamp bucket.jpg (23.05 KiB) Viewed 123805 times
Headlamp retaining ring.jpg (46.26 KiB) Viewed 123805 times
Midnight_Rider
My Cars: 71 Plymouth Road Runner
Post by Midnight_Rider » Wed Aug 15, 2018 4:34 pm
We need a 'LIKE' button around here... :beer:
Post by sdweatherman » Mon Jan 10, 2022 4:20 pm
Lotsa good progress here through 2018, any updates? Or did it go on the "back burner"?
Thanks, Scott.
Post by rr6pak » Mon Jan 10, 2022 4:42 pm
Good to hear from you Scott. She is mostly done but have some interior to do and some odds and ends. I've had foot surgery that s***s and weight bearing. Before surgery, I had to drop the rear end because the pinion seal was leaking. I then installed a rear stabilizer bar to go with the front one. Dealing with a few mechanical issues prior as well. Seems the carb was too big and put a little smaller one on, then surgery :? Anyway, as soon as I can get back on her, the better.
Post by sdweatherman » Mon Jan 10, 2022 4:55 pm
Whoa! Big jump in progress! Looking awesome. What did you decide engine wise on this one - I remember you posting the original 383 was long gone, but a 1969 year 383 was in its place?
Post by rr6pak » Mon Jan 10, 2022 5:01 pm
The 383 wasn't gone but it wasn't original. We found that out by the serial numbers. So, I had a 400 stroked out to 470 C.I. Had it dyno tested and hit 600 HP and 610 torque. The horsepower might have gone done a little because I had to switch to a little smaller carb. I guess the guy who built it put the biggets on to hit max H.P and torque. Will I need it, probably not but sure is a good conversation piece.
#3 Rod RH (2).jpg (153.13 KiB) Viewed 118648 times
Post by sdweatherman » Mon Jan 10, 2022 5:03 pm
Awesome - sounds like adequate HP to me! Thanks for catching us up, and enjoy!!
Post by rr6pak » Mon Jan 10, 2022 5:06 pm
Thanks! I need to order the correct Rallys and new tires. The car still has 0 miles and still on the same tires and rims from when my dad got them and put them on 30 years ago.
