taking off some mud.
bandman1971
My Cars: possibly buying a butterscotch 1971 RR 383, automatic on the floor.
Post by bandman1971 » Sun Apr 01, 2012 11:17 pm
Well I broke out the heat gun and applied some muscle to obvious repairs. Here's what I found....
Riveted repair from a while ago....
Passenger rear
Passenger rear in front of rear tire
bandman1971
Re: taking off some mud.
Post by bandman1971 » Sun Apr 01, 2012 11:21 pm
Other side....
rivited repair from back in the day.
drivers rear behind tire is clean.
bandman1971
Post by bandman1971 » Sun Apr 01, 2012 11:25 pm
I also have a crack at the top of my drivers side door. It moves when weight it applied. Repairable?
drivers door crack
bandman1971
Post by bandman1971 » Sun Apr 01, 2012 11:29 pm
Advice on how to proceed........
Should I break out some media and start blasting the entire car till all the metal is exposed? Or is that overkill for a one day dairly driver? Should I get it dipped and have someone who knows what the heck they are doing repair the metal?
71ChallengerSE
1971 Dodge Demon 'Sizzler'
Post by 71ChallengerSE » Mon Apr 02, 2012 12:36 am
For the exterior I would use paint stripper on all panels, repair the rust properly with patches or panels as needed. Treat any rust with rust bullet. Depends on the amount of rust or rot but if you are only expecting a driver there is no need for media blasting or dipping. As for the door crack, I would grind out the crack a little bit and fill it with weld. Grind it smooth and finish it off.
Post by Eric » Mon Apr 02, 2012 12:00 pm
bandman1971 wrote:I also have a crack at the top of my drivers side door. It moves when weight it applied. Repairable?
I believe every unrestored 71 B I've owned had a crack there
GTXplicity
My Cars: '71 Plymouth GTX
Post by GTXplicity » Mon Apr 02, 2012 12:42 pm
Yeah, what's up with that? My 39k mile GTX has that crack on both doors. And that's after being painted twice. Factory/engineering defect? :?
1bluegtx
Post by 1bluegtx » Tue Apr 03, 2012 12:38 am
Yep,i have the door crack to!
Its not numbers matching
It doesn't run on pump gas
11.73 at 115mph
Post by 72RoadRunnerGTX » Tue Apr 03, 2012 12:41 am
Here’s an updated past thread about the door cracks.
Admins; this is a thread that contains an older post from AZ Nick. His signature contains a dead link to a picture file prompting a server log-in somewhere; enter cancel to skip through it. Is there any way to edit this link out of his signatures? I understand he may have retired and may no longer be active on the site.
Post by Eric » Tue Apr 03, 2012 12:03 pm
72RoadRunnerGTX wrote:Here’s an updated past thread about the door cracks.
done
