taking off some mud.
bandman1971
- My Cars: possibly buying a butterscotch 1971 RR 383, automatic on the floor.
Well I broke out the heat gun and applied some muscle to obvious repairs. Here's what I found....
Riveted repair from a while ago....
- Passenger rear in front of rear tire
- DSCN1009.JPG (122.97 KiB) Viewed 19909 times
bandman1971
Re: taking off some mud.
Other side....
- rivited repair from back in the day.
- DSCN1006.JPG (122.86 KiB) Viewed 19909 times
- drivers rear behind tire is clean.
- DSCN1007.JPG (121.35 KiB) Viewed 19909 times
bandman1971
I also have a crack at the top of my drivers side door. It moves when weight it applied. Repairable?
- drivers door crack
- DSCN1013.JPG (121.15 KiB) Viewed 19909 times
bandman1971
Advice on how to proceed........
Should I break out some media and start blasting the entire car till all the metal is exposed? Or is that overkill for a one day dairly driver? Should I get it dipped and have someone who knows what the heck they are doing repair the metal?
- 71ChallengerSE
1971 Dodge Demon 'Sizzler'
For the exterior I would use paint stripper on all panels, repair the rust properly with patches or panels as needed. Treat any rust with rust bullet. Depends on the amount of rust or rot but if you are only expecting a driver there is no need for media blasting or dipping. As for the door crack, I would grind out the crack a little bit and fill it with weld. Grind it smooth and finish it off.
I believe every unrestored 71 B I've owned had a crack therebandman1971 wrote:I also have a crack at the top of my drivers side door. It moves when weight it applied. Repairable?
GTXplicity
- My Cars: '71 Plymouth GTX
Yeah, what's up with that? My 39k mile GTX has that crack on both doors. And that's after being painted twice. Factory/engineering defect?Eric wrote:I believe every unrestored 71 B I've owned had a crack therebandman1971 wrote:I also have a crack at the top of my drivers side door. It moves when weight it applied. Repairable?
Yep,i have the door crack to!
Its not numbers matching
It doesn't run on pump gas
11.73 at 115mph
11.73 at 115mph
Here’s an updated past thread about the door cracks.
Admins; this is a thread that contains an older post from AZ Nick. His signature contains a dead link to a picture file prompting a server log-in somewhere; enter cancel to skip through it. Is there any way to edit this link out of his signatures? I understand he may have retired and may no longer be active on the site.
done72RoadRunnerGTX wrote:Here’s an updated past thread about the door cracks.
