Rust holes in all quarter & fender lowers, a bit on the extensions as well. Frames rails rock solid, floors look good.
Album here: http://s449.photobucket.com/albums/qq21 ... Satellite/
Well, color me ignorant! I really should have known this, but it looked small to me. Must be because it's up on a trailer. (Yeah, good excuse.)moparite wrote:This car has 9 1/4 rear not the 8 1/4. Note the taper in the axle tube and large brake drums. Thats a plus, it's a strong rear.
a E -body is 60in drum to drum and 71-74b- body 62 in drum to drumElvad wrote:The 8 1/4 rear end is commonly found in a-bodys, even with a 318. My friends and I refer to it as a 'potato chip' rear end because of the loud crunching noise it will eventually make when it blows up. The 9 1/4 is no better. I disagree with the last guy, it is not a strong piece. The same rear end is in use today in new Dodge trucks and fails pinion bearings and blows up all the time. You want to find an 8 3/4 or Dana 60. Remember! The 71-72 Satellite has a wider rear end than a normal B body. So get one out of one of those cars or out of an E body. Or just go to http://www.moserengineering.com and buy it all new. Good Luck cool car.
