1972 SSP 400-4BBL Progress
Re: 1972 SSP 400-4BBL Progress
Post by 71440 gtx » Thu Feb 26, 2009 12:17 am
The Chrysler 8-3/4" rear axle assembly was introduced in 1957. It is a banjo-type (Hotchkiss) axle, ie. the differential is contained in a removable carrier assembly. The axle has an 8-3/4" diameter ring gear. There are three basic types available distinguished by their drive pinion stem diameter. The 8-3/4" axle was the primary axle assembly and saw continued use until 1974.
the 1972 a body was the last year for 8.34 1973 a body have a 8.25
DixieSatellite
Post by DixieSatellite » Sat Feb 28, 2009 7:13 am
How the car usually is when I get to play with it....
Washing off the dust
All clean again
Engine bay work should be completed end of next week.
Interior requires a fair bit of work.
Ian B.
Post by 71440 gtx » Sat Feb 28, 2009 10:53 am
woooooooooooooooooooooow nice car :beer:
Post by landon1 » Sat Feb 28, 2009 12:01 pm
are those guards around the door locks to keep your paint from getting scratched??? pretty cool item - probably won't find those anywhere
DixieSatellite
Post by DixieSatellite » Sun Mar 01, 2009 12:12 am
landon1 wrote:are those guards around the door locks to keep your paint from getting scratched??? pretty cool item - probably won't find those anywhere
Hi,
Yes, they were on the car when it was bought back in 1991. Same for the door edge protectors.
Latest engine pics here.
Before
Now
Ian B.
ct71rr
Post by ct71rr » Sun Mar 01, 2009 2:51 pm
Very nice :beer:
DixieSatellite
Post by DixieSatellite » Fri Mar 06, 2009 7:29 am
Engine Update:
dartomotive
Post by dartomotive » Sun Mar 08, 2009 6:33 am
Good chart. I really like the white. This is going to be an awesome car. Good luck. Mike
DixieSatellite
Post by DixieSatellite » Sun Mar 22, 2009 12:19 am
Some more progress pics for those interested.
Ian B.
moparmike
Post by moparmike » Sun Mar 22, 2009 10:17 am
Love it, I am also restoring my 72 Sebring Plus as a survivor car, you just do not see many of them done this way any more. Nice to watch it come together and very helpfull to me as well.
1972 Clonerunner
Post by 1972 Clonerunner » Mon Apr 06, 2009 9:26 pm
When I was growing up my Dads everyday driver was a 1972 SSP. It was powered by a 400 4 bbl 4 speed. He had headers on it , man I can remember the roar when that old Thermobog kicked in. It went like crazy for what it was. He drove the snot out of it, that old 400 wouldn't quit. It was orig brown on the top with gray on the bottom with a green interrior , he had it repainted green . Buckets and console car. Loved that car.
Check out my cardomain page about my Sat project. http://www.cardomain.com/ride/3312538
DixieSatellite
Post by DixieSatellite » Sun Apr 26, 2009 3:15 am
More pics.
Ian B.
Post by Smellslike1974 » Mon Apr 27, 2009 12:03 am
Are you sure that guide Is100% accurate?Can anyone approve this?ha ha
DixieSatellite
Post by DixieSatellite » Sat Aug 22, 2009 9:57 pm
Deleted
Last edited by DixieSatellite on Fri Sep 04, 2009 7:24 am, edited 1 time in total.
DixieSatellite
Post by DixieSatellite » Fri Sep 04, 2009 7:22 am
Hi,
Engine and air-con system (ice-cold) are finally together, which has pretty much finished my budget for now. Here are the latest pics as to what a factory new '72 Plymouth Satellite Sebring Plus 400-4BBL should look like (well, in the engine bay, anyway). The rest of the car needs a some more beautification and attention to the bodywork, but more has been done in the last 16 months than in the last 16 years.
For those interested :-
Engine Specs
Chrysler 400, Bore 4.372, Stroke 3.380, Cylinder volume 831.51 cc Total volume 405.9 CI, Intake valves 2.080, Exhaust valves 1.650, Compression ratio 9.00, Manifold Dual-plane std-flow, carb flow 800.0 CFM, peak Horsepower "304.3", Peak Torque 414.8. This engine will run fine on pump fuel with a increase in horsepower of 30% over stock engine.
Designed to be mild rather than wild, but able to cruise all day long well above the limit w/ lots of 'passing power'.
Ian B.
Image[/quote]
