non resto question
non resto question
got a question about oil pans and pickups. want to put a 440 from a demolition derby car(2nd place!) which was a 77 royal monaco into a 77 cordoba for next derby and after slightly tweaking the small block mounts i realised the oil pan sump will hit the crossmember. can you just swap the oil pan end for end? and is there a pickup tube that will work here?
